  #61
Old 10-25-2019, 01:47 PM
ChuckS ChuckS is offline
Default Re: PT restarts automatically after closing it
Already a couple of threads about this.
http://duc.avid.com/showthread.php?t...hlight=restart
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
  #62
Old 10-25-2019, 02:57 PM
Jordan_J Jordan_J is offline
Default Re: Pro Tools 2019.6 (Win 10) starts itself?
Originally Posted by guitardom View Post
This has been pretty well resolved back to the Ilok driver. It has been advised to roll back.
Can you, please, provide a link where this issue has been discussed and resolved?
Thanks a lot in advance!
  #63
Old 10-25-2019, 03:02 PM
Elfuello Elfuello is offline
Without solution and only one post, sorry. ;-)
  #64
Old 10-25-2019, 03:03 PM
Originally Posted by ChuckS View Post
This happens here also. In the event viewer, the crash references ucrtbase.dll which is a Windows Visual C++ runtime file. So basically any plug/module/etc written in C++ could be causing the crash. Another side issue of this is that it creates crash dumps every time you exit PT so there could be gigabytes of dumps accumulating if you don't use a cleaner app. Check here for files: C:\Users\~yourusername\AppData\Local\CrashDumps
Thing is that even if you don't get the restart issue, PT is still crashing on quit and creating crash dumps on exit. Anyone any good at reading those may be able to isolate the issue.
Check this thread out:
https://superuser.com/questions/1397...o-ucrtbase-dll
I will try to resolve it as explained here.
P.S. Reinstalled the Windows 10 SDK (26624) but it didn't resolve the issue.
Also checked for crash reports - I don't have any since 2018! It seems that Pro Tools doesn't crash. At least the crash reports suggest that. How to fix this?!
  #65
Old 10-27-2019, 02:10 AM
PROBLEM SOLVED!
The problem really is the iLok driver.
I uninstalled the latest iLok driver that I had currently in use.
Went to https://www.ilok.com/#!resource/legacy and downloaded the legacy version installer LicenseSupportInstallerWin64_v2_4_8_r37293.zip
Installed it and PROBLEM SOLVED!
Thanks a lot for the tip @guitardom!
  #66
Old 10-27-2019, 03:12 AM
deanrichard deanrichard is offline
I'm glad that solved your problem, but why on earth should you need to use a legacy iLok driver to keep your application from restarting? That is some really weird behavior, and hopefully Avid will have that one fixed.
Originally Posted by Jordan_J View Post
PROBLEM SOLVED!
  #67
Old 10-27-2019, 08:49 AM
Default Problem solved :-)
Latest iLok driver makes the problem!
1) Uninstall PACE (iLok Manager) from you Windows Aplications
2) Install iLok (Pace) driver 2.4.8 (x64):
http://installers.ilok.com/iloklicen...4_8_r37293.zip
3) Restart system.
Now my Pro Tools 2019.6 has no problems.
CHEERS!
  #68
Old 10-27-2019, 09:27 AM
grayter1 grayter1 is offline
Default Re: Problem solved :-)
3) Restart system.
CHEERS!
Just did this and it worked.
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X
  #69
Old 10-27-2019, 12:58 PM
That's the question that we're all trying to figure out.
Hopefully iLok will fix it with a soon update!
  #70
Old 10-28-2019, 03:53 AM
jehjinho jehjinho is offline
really?
I did the rollback and now my pro tools 2019.6 requires a newer version of licence support software in order to run...
so, no solution here...
12.7 .0.676 Install Update Prompt Endless Loop AVIDIVA Pro Tools 12 2 12-22-2016 01:26 AM
Activating my PT9 to PT10-PT11 upgrade is an endless loop? mike_mccue Windows 1 06-23-2013 03:45 PM
Core audio - sound stuck in endless loop lpbaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-23-2010 08:03 AM
Bounce to Disk creates endless loop boneboy Pro Tools TDM Systems (Mac) 2 08-13-2006 08:05 PM
Need Help with endless loop Mark Manela Pro Tools TDM Systems (Mac) 1 05-28-2002 04:27 PM
