Old 03-05-2003, 11:07 AM
maslusher maslusher is offline
Default Midi loops
Ive never done alot of midi before and have a few questions. What is the easiest and best way to record a single mesure drum loop and then duplicate it into a long loop. It seems that when I try it even after quantizing things still dont always stay in line. Seems like I remember someone saying to set your view to grid or something like that but I cant remember. Thanks in advanced.
Old 03-06-2003, 12:18 AM
Roy Howell Roy Howell is offline
Default Re: Midi loops
maslusher,
Yes, put it in Grid mode, set your bpm to the tempo you want. Once you've recorded the measure(s) you want, highlight them, and quantize them.
Once quantized, highlight it/them, and hit Alt/R(repeat), and enter as many repeats as you want.
If you simply want it to loop within the same area, highlight it, and right click on the Play button. Push play and it will loop continuously. To get out of 'loop' mode, right click Play again.
rh music
MIDI Loops Source? DonaldM The Drum Room 4 03-26-2013 07:46 AM
Auditioning MIDI loops scripguy macOS 0 01-18-2013 09:54 AM
MIDI loops for Strike DonaldM The Drum Room 3 09-28-2012 07:28 AM
DRUM LOOPS AND MIDI Abomb97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-16-2003 03:57 PM
Need help with MIDI drums, loops Ritchie Digidesign Hardware & Software 6 01-02-2001 04:43 PM
