Old 09-13-2017, 09:17 AM
antonis's Avatar
antonis antonis is offline
Default LtRt AAX plugin
I need to get one. Is Neyrinck still the best option?
Old 09-13-2017, 09:21 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default Re: LtRt AAX plugin
Really sure you need LtRt rather than LoRo? Most people will take Stereo rather than matrix as so few people need matrix these days - it was a solution to get around lack of discreet surround which has gone away now.
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 09-13-2017, 09:43 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
+1. Don't remember last three years delivering anything but LoRo.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 09-13-2017, 10:44 AM
MatzeHD MatzeHD is offline
I think, its always better to make a matrix compatible downmix, because it sounds better on only Stereo too!
The difference from a automatic downmix from LoRo to matrix compatibe was only, that the Surround Channels are inverted mixed to L and R!?
Old 09-13-2017, 11:23 AM
Using Minnetonka SurCode Pro Logic II here. It can do encode/decode cycle to check how the decode sounds.
EDIT: It looks like the Neyrinck can do real-time encode/decode as well. I'm not sure why I thought it couldn't.
Scott Gatteño
Old 09-13-2017, 02:27 PM
smurfyou smurfyou is offline
I think the LoRo sounds much better compared to an LtRt in stereo.
~Will
Old 09-13-2017, 06:18 PM
Leverson Leverson is offline
I agree, I like the sound of LoRo better than LtRt. I can't wait for LtRt to go fully extinct. But that being said I still have to deliver LtRt all the time for film and TV, it's definitely not a dead deliverable yet.
Your two best bets are Minnetonka's Surcode, or Neyrinks SoundCode. (Check the product name on the websites and make sure you are looking at the correct one for Dolby Pro Logic II LtRt).
I use Surcode and it works great. It allows you to monitor encoded or decoded or passthrough. I'm sure the Neyrink version works great as well and does the same.
Old 09-14-2017, 01:42 AM
Hi!
And why LoRo? Theoretical, if Surrounds mixed inverted to the Stereodownmix, you have a more diffuse sound with the signals.Until 10 years or so, this was standard, sometimes the 5.1 downmix to stereo was manually improved and this allow maximum quality. In the most cases today,its no longer carried out and many downmix sound bad!
Old 09-14-2017, 02:21 AM
antonis's Avatar
Hey Mike,
Good point.
Well, the delivery specs definitely states LtRt. This is for a documentary but it is not going straight to the broadcaster. Instead, it goes to one of those media agencies that sells media worldwide. I'll see if I can email them and check whether they do want LtRt for a specific reason or see if they can see the benefits of a LoRo.
Old 09-14-2017, 02:22 AM
antonis's Avatar
Cool. I was aware of these two. I wasn't sure whether another contender might have been out in the market as well.
Great, thanks.
HTML code is On
LtRt Question sonichead Post - Surround - Video 8 09-03-2013 01:45 PM
5.1 to LtRt zzstation Post - Surround - Video 3 05-25-2012 12:19 PM
Neyrink LtRt plugin: container lululu Post - Surround - Video 4 08-12-2011 09:06 AM
Some LtRt quesitons Newpostguy Post - Surround - Video 11 08-18-2010 06:08 AM
How do i create an LtRt mix from 5.1? Andy Hay Post - Surround - Video 18 11-08-2004 09:46 AM
