Old 04-25-2017, 10:21 PM
3volution 3volution is offline
Default Cubase Crackling AudioTracks! (Mbox2)
Hey I am experiencing audio clicks and crackling at random intervals it is not the recorded audio it is not the cpu or vst performance I have reinstalled drivers a thousand times Asio Mbox 2 driver and Asio4all..
The Asio4all just clicks and nothing is playable and the Mbox asio can play midi cleanly no artifacts but any audio tracks click crackle and pop lol. (I am very frustrated after tons of wasted time 10+ hours troubleshooting)
Reinstalled cubase although only a repair reinstalled I don't want to unistalled and have to reinstall all my plugs and 3rd party as well.
Ummm... so yea the mic is fine I can use other daws and the card works perfect so its not the interface.
The Asio4all doesnt seem to work in other daws atm driver just drops right away.
Not sure what I am missing here...
Old 04-26-2017, 08:01 AM
Default Re: Cubase Crackling AudioTracks! (Mbox2)
shooting from the hip as I am not a Cubase users, but in my experience, ASIO4ALL is a "last-ditch" driver and since Mbox has decent drivers, I see no reason to use ASIO4ALL and would uninstall it. Besides that, the last time I used ASIO4ALL, it not only worked badly, it caused my 003 to not work at all
Old 04-26-2017, 12:19 PM
JoelG's Avatar
JoelG JoelG is offline
To further Albee's post, there seems to be some misunderstanding by a LOT of users as to what ASIO4ALL purpose actually is. It is a wrapper for WDM drivers, for devices that don't have their own ASIO drivers (the Mbox does). It is useful if you're trying to use your onboard soundcard for example.
Beyond that, be sure to go through all of the Optimisation Guide, and if you could post your full system specs, that would be helpful.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 04-27-2017, 09:22 PM
I hope this is the proper way to copy. Also the Mbox about 3 weeks ago did not glitch at all not sure what happened in that time. (No updates or anything)
Going to try a few things out I will post the progress tomorrow Thank you both for the replies I appreciate you both!
SiSoftware Sandra
ID
Host Name : Cloud-PC
Workgroup : WORKGROUP
Computer
Model : ASUS G73Jh
Serial Number : SSN1234567**********
Chassis : ASUS Notebook
Mainboard : ASUS G73Jh
Serial Number : BSN1234567**********
BIOS : AMI (OEM) G73Jh.213 01/27/2011
Intel vPro : 6.00.03.1195
Total Memory : 6GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM) i7 CPU Q 840 @ 1.87GHz (4C 8T 2GHz/3.19GHz, 2GHz IMC, 4x 256kB L2, 8MB L3)
Socket/Slot : FC PGA988 (G2)
Chipset
Memory Controller : ASUS Core (Clarksfield/Lynnfield) DMI 2x 2.4GHz (4.79GHz)
Memory Controller : Intel Core Mobile (Clarksfield) UnCore 2x 2.4GHz (4.79GHz), 2x 3GB DDR3 SO-DIMM 1.33GHz 128-bit
Memory Module(s)
Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700SO DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : HSD173PUW1
(1920x1080, 17.3")
Video Adapter : AMD Mobility Radeon HD 5800 Series (10CU 720SP SM5.0 700MHz, 1GB DDR5 4GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : AMD Mobility Radeon HD 5800 Series (800SP 10C 700MHz, 1GB DDR5 4GHz 128-bit)
Compute Shader Processor : AMD Mobility Radeon HD 5800 Series (720SP 10C 700MHz, 1GB DDR5 4GHz 128-bit)
OpenGL Processor : AMD Mobility Radeon HD 5800 Series (720SP 10C 700MHz, 1GB DDR5 4GHz 128-bit)
Storage Devices
Crucial M4-CT512M4SSD2 (512.1GB, SATA300/600, 2.5", SSD) : 477GB (C:)
Seagate ST3000DM001-1CH166 (3TB, USB2/SATA300/600, 3.5", 7200rpm) : 3TB (H:)
TSSTcorp CDDVDW TS-L633C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
System Reserved : 100MB (NTFS, 4kB) @ Crucial M4-CT512M4SSD2 (512.1GB, SATA300/600, 2.5", SSD)
HD-LXU3 (H:) : 3TB (NTFS, 4kB) @ Seagate ST3000DM001-1CH166 (3TB, USB2/SATA300/600, 3.5", 7200rpm)
Hard Disk (C:) : 477GB (NTFS, 4kB) @ Crucial M4-CT512M4SSD2 (512.1GB, SATA300/600, 2.5", SSD)
Optical Drive (E:) : N/A @ TSSTcorp CDDVDW TS-L633C (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS HM55 LPC Interface Controller
Audio Device : ASUS ASUSTek G73-series gaming laptop
Audio Codec : Realtek Semi High Definition Audio
Audio Device : ASUS EG JUNIPER XT Audio Device [Radeon HD 5700 Series]
Audio Codec : ATI (AMD) HDMI Audio
Disk Controller : ASUS P55/PM55/3400 4 port SATA AHCI Controller
USB Controller 1 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20) (Ethernet)
Wireless Adapter : Atheros AR9285 Wireless Network Adapter (802.11n (HT), AES-CCMP, 65Mbps)
Power Management
Battery No 1 : ASUSTek 72.80Wh/7.81Ah
Operating System
Windows System : Microsoft Windows 7 Personal 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Performance Enhancing Tips
Warning 2513 : TPM not detected. Some security features are unavailable.
Warning 225 : CPU is not a production version but ES/QS.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 05-21-2017, 02:44 PM
Default Re: FIXED Cubase Crackling AudioTracks! (Mbox2)
I figured a FIX and posted it in the cubase forum: https://www.steinberg.net/forums/vie...640563#p640563
Basically I had too many Visual C++ redistributables installed both 32 and 64bit instead of one or the other so I unistalled and reinstalled all the years only 64bit and updates and my Asio4all driver works perfect like it did a month ago. Although the Mbox original driver is not working even after reinstalled driver. (crackling and pops on a project with 1 audio track and 2 seconds of audio)
mbox2 crackling/static...!!!! 5teph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 06-22-2023 12:19 PM
Problems with crackling / static when recording (Windows 7) Mbox2 zorkiii Windows 24 11-08-2015 08:44 PM
mbox2 periodic crackling and distortion grafic macOS 11 02-14-2015 10:38 AM
Serious mbox2 crackling issue xcolbeyx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 28 05-30-2011 12:05 PM
Mbox2 Crackling in Monitors AND Headphones...HELP!!!! xcolbeyx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-06-2010 08:59 AM
