Old 09-20-2014, 12:15 AM
borntobemild borntobemild is offline
Default !!HD native Thunderbolt device doesn't boot!!
Hi folks,
I'm absolutely clueless!
Yesterday I had a session running... all day long... no problems and everything seems to work fine!
After the work has been done I disconnected my HD native thunderbolt (with HD OMNI as an interface).
A few minutes later something regarding the project popped up on my mind and I connected the unit again... and then BOOOOM..... NOTHING happened!!!!
The LED stood blank and a high, "rhythmical" noise kinda whistling was noticeable!
Disconnected the TB-Cable and plugged it in again....no effect!
What went wrong and more important how to fix it??!
I need the unit at least next week, I resident in Germany and it is unthinkable first to get an RMA and then send it to AVID and wait for weeks....sorry.
Is there another option??
My Setup:
Macbook Pro retina (late 2013), OS X 10.9.4, PT HD 11.2.1, latest AVID Drivers and Firmwares, HD native TB + HD OMNI, TB-Display
Thanks a lot in advance for any type of help!
Cheers,
Stefan
Old 09-20-2014, 12:40 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: !!HD native Thunderbolt device doesn't boot!!
Relax.
First check if the red/green light powers up when you connect the TB cable. If so, you have a software issue which hopefully can be solved quicker than doing a complete reinstall of the system.
If it doesn't, then the unit does not power up, which means the problem is either:
- the TB cable (check with another one)
- the TB port on your computer (check with another one)
- the TB port on your HDN box (call your avid dealer and get it serviced)
Double-check this and report back with more info.
Janne
Old 09-20-2014, 12:48 AM
Hi JFreak,
thanks for your quick answer!
Well, the status LED doesn't do anything.
There is something happening inside the device...so I guess the TB-Cable is working and my TB-Port (I tried another one and I tried the TB-Display on each port) on my MB is also fine.
I would say that the TB-connection on my HDN is also working more or less quite properly... because there's this quiet, high rhythmical noise/whistling kinda thing inside my HDN when It's connected or at least tries to do so....
Cheers!
Old 09-20-2014, 12:49 AM
JFreak's Avatar
If the led does not come up, the unit has not powered up. I had mine serviced because of that
Janne
Old 09-20-2014, 12:50 AM
JFreak's Avatar
Have you by any chance used the box daisy-chained to an Apple TB display? Mine was, and whether I have no idea if that was the problem, I'm not foing to do that anymore
Janne
Old 09-20-2014, 12:54 AM
okay, well no. I'm always using it on a seperate TB-port.
So the best thing would be to contact the technical support where I bought it, right?
Old 09-20-2014, 12:55 AM
JFreak's Avatar
Sadly, I think so. But it will take 1-2 weeks to get it serviced (in Ireland) so you better negotiate a rental if you need it next week.
Janne
Old 09-20-2014, 12:59 AM
puhh
But well, okay then....Thanks a lot! :)
Old 09-20-2014, 01:00 AM
JFreak's Avatar
You're welcome. And welcome to the forum :)
Janne
Thunderbolt 3.0 & HD Native Table Syrup Records Pro Tools HDX & HD Native Systems (Mac) 1 04-23-2014 04:49 PM
HD native thunderbolt through Echo Express SE Thunderbolt Chassis hkj1 Pro Tools HDX & HD Native Systems (Mac) 1 11-06-2013 05:49 PM
Exchange HD Native PCI-e for HD native Thunderbolt sinewavz Buy & Sell 0 06-25-2013 08:26 AM
Anybody switched to a Macbook Pro Thunderbolt Native from Mac Pro Native? petesteen Pro Tools HDX & HD Native Systems (Mac) 7 11-17-2012 03:21 PM
OMNI-2 HDX = new thunderbolt device with on board HDX prophecy Pro Tools TDM Systems (Mac) 16 10-27-2011 12:35 PM
