Old 02-20-2014, 06:31 PM
fullfluxstudios fullfluxstudios is offline
Default (-1166) Firmware issue Mac Pro / Native PCIe
I'm running 10.8.5 on a Dual 2.8GHz quad core 2008 Mac Pro with 4 Gigs Ram.
What I've tried so far..
- Repeatedly opening Pro Tools and retrying the firmware update.
- Moving the Native Card from slot 1 to slot 4.
- uninstalling Pro Tools 10, doing the firmware updater, reinstalling pro tools 10
- doing the same as above but with pro tools 11.
- Physically resetting the Native Card by pushing the button on the card, waiting 5 seconds, then pushing the button again.. then reseting the computer, then reopening Pro Tools.
After each and every attempt it still gives me the "An Unexpected Error occured while transmitting a firmware image. Error while writing the image to the card. (-1166)
I know the card is good because I tested it in another Mac Pro before purchasing it.
Any help would be greatly appreciated.
Old 02-20-2014, 11:31 PM
nst7 nst7 is offline
Default Re: (-1166) Firmware issue Mac Pro / Native PCIe
My Native card is in the 2nd slot down from the top. I originally moved it because I couldn't do the firmware update on the card. When I moved it, I could do the firmware update, and I just left it there because everything was working fine.
So you might try that as well.
Old 02-21-2014, 05:35 AM
Bookerv12 Bookerv12 is offline
I had the same problem.
The only way to do it on a Mac was with OSX.6, which we didn't have .
In the end, we ended up having to do the update on a PC, first installing PT 10 on the machine, and running as an administrator.
Then it worked.
I have blocked out all of the details.
bookerv12
Old 02-22-2014, 11:48 AM
Ok.. So if I can get my hands on OSX 10.6 then I'm good. Thats much more likely then finding a PC to do it on.
User, nst7, what OS are you running? I originally had the card in slot 1, then moved it to slot 4. I'll try slot 3 as well just to see what happens.
Bookerv12, thanks for the heads up. That definitely helps point me in the right direction.
Old 02-22-2014, 01:12 PM
I am on 10.7.4., running HD10.2.
Old 03-02-2014, 09:37 PM
I got it working. Here is what I did.
I formatted the system drive, which was running 10.8, and loaded in the Snow Leopard OSX install disc (its also available in the Apple App Store for $20 if you don't have the install CD). Installed 10.6, then via Apples website downloaded all of the 10.6.x updates, up to 10.6.7.
I then Installed Pro Tools 10 (non HD)
Pro Tools did its typical 'Need to Flash the Firmware.. yadda yadda yadda' and after 9 HOURS of a spinning wheel of death... TAH DAH! It works!
I'm running pro tools 10 (non HD) with a Native Card and a Digi 192 on a Mac Pro dual Quad Core bad mamma jamma. And I'm stoked =]
Just wanted to give an update to anybody else in that situation.
-B
Old 03-03-2014, 03:38 PM
feliponk's Avatar
feliponk feliponk is offline
How can you run Pro Tools 10 non HD with an HD Native card?, only the HD version can see and use the HD boards and I/O, it doesn't make sense.
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 03-03-2014, 08:38 PM
I'm not sure where you got your information.. but I can access the Native Card and go into hardware setup and set all the inputs and outputs on the 192 just like in HD.
Works like a charm.. minus a few bells and whistles.
Old 03-03-2014, 10:40 PM
He's not the only one to confirm this. Someone else mentioned it as well, that HD Native hardware will work with the non-HD PT11 or 10 license. I assume that means they don't have the extra features. I don't know if this is something Avid overlooked, or if they changed it to be this way. If so, it opens up more possibilities for people to buy second hand HD Native hardware and use it with an existing non-HD license, if they don't need the extra software features.
Old 03-04-2014, 02:04 PM
Hmmmmm...
We tried getting that to work on a friend's machine and couldn't.
I'm glad you could.
That's pretty bad mamma jamma!
bookerv12
HD Native PCIe + Symphony I/O + Magma Express Box 3T Issue stevepoint Pro Tools HDX & HD Native Systems (Mac) 0 02-11-2014 09:04 AM
Using PT9 with HD Native PCIE KSR macOS 1 12-19-2013 12:28 PM
HD Native PCIe on Imac I5 Vikingjive General Discussion 7 04-20-2012 06:29 AM
HD Native Firmware updater issue protoolsuserman Pro Tools HDX & HD Native Systems (Mac) 15 03-25-2012 09:26 AM
Considering switching from HD3 PCIe to HD Native drumster Pro Tools HDX & HD Native Systems (Mac) 150 02-11-2012 08:23 AM
