please, i need advice for av888/1622
hi to all from cyprus
i am katerina anachioti from cyprus and i am a musician and a radio music producer i am planning to buy an audio interface for my musical needs and please i would like to know some things about the digidesign model av888/1622 prior my purchase date of manufactured av888/1622 what are the main differences between those tow models what pro tools music software can i use (version) if i can use other than pro tools music software with those audio interfaces usb or firewire connection can be used as standalone device can be used for monitoring within my daw and my active monitors my seller at my music local store found for me through ebay a used av888/1622 interface but unfortunately he can answer all these questions so please kindly advice many thanks in advance katerina cyprus Last edited by katerinacyprus; 05-23-2013 at 07:39 AM. |
Re: please, i need advice for av888/1622
HI, Both those interfaces are old and ONLY work with a digidesign mix core card or farm card or connected to the legacy port on a HD interface. They do not work any other way so you would need a mix core card or HD core card plus interface. Fundamentally they are no good to anyone unless they already have a pro tools system to connect them to. they do not work as standalone etc. Depending on how many inputs and outputs you need you would be better looking for an 003 interface maybe? or something new with 8 ins and outs etc. Chris
If you want to use those old boxes, you will need an old computer (if you're using Macs, it means older than 2003) and a MIX card for every 16 channels of i/o you need.
good morning to all from cyprus
i really thank all very much for the detailed informations i will take your advice and i will check to find a newer audio interface for my needs an audio interface with 8 ins 2 outs plus digital in/out and midi in/out are all i need so i have to alk with my local music store seller thanks again to all katerina - cyprus |
1622 vs. 822/20 | Philee | Digidesign Hardware & Software | 7 | 09-27-2010 08:45 PM |
Advice Please - Rosetta 800 and Digi 1622 issues? | Rockman-Songwriter | Pro Tools TDM Systems (Mac) | 4 | 04-03-2005 09:34 PM |
PT 4.3.2 and a 1622 | E-an | Pro Tools TDM Systems (Mac) | 1 | 10-15-2002 09:26 AM |
1622 DAE Bug? | ditherwerk | Pro Tools TDM Systems (Mac) | 20 | 04-24-2002 07:45 AM |
1622 | Kurtstudio | Pro Tools TDM Systems (Mac) | 2 | 06-15-2000 07:09 AM |
