Elastic Audio on Multi-Miced Electric Guitars... PLEASE HELP!!!
I started using elastic audio the day it came out and won't ever use beat detective again for tempo correction on drums... I LOVE IT! However, recently on my HD 2 system I've noticed when I try and manipulate a multi-miced guitar i'm getting phasing issues like crazy... The thing that's driving me crazy is I have all 3 mics grouped, I'm using the Polyphonic Algorithm and this method works perfectly on drums and other multi-miced sources as far as I have come across... (of course using the rhythmic algorithm on drums)...
Anyone else have any issues with MULTI-Miced guitar amps? These guitar parts in particular happen to be very overdriven. I used an SM57, an AKG Solidtube and a Sennheiser E609 to mic a Vox AC15 HTV amp. If I left anything out or you want to know more about my setup let me know. All help is greatly appreciated! God Bless, David Glenn Spiritwalk Productions http://www.myspace.com/azmythrecording [email protected] |
Re: Elastic Audio on Multi-Miced Electric Guitars... PLEASE HELP!!!
Hey David, I'll experiment tomorrow, but I can see, with as "Constant, and Saturated" an electric guitar is, if EA is doing ANYTHING different to the algorithm on one of the other tracks, I can imaging the phasing, quite intense.
I'd actually play with "Rhythmic" mode for these grouped guitars, as this mode really applies a series of Crossfades, and doesn't "Process" or Alter the audio.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
It's also VERY important that you create an edit group to keep phase coherency when using EA, be it Drums or Guitars. Try that and see if it helps.
AKA - EvilElfHobo Pro Tools 10 HD Native | Mbox 3 Pro | MacBook Pro 2.3 i5 | OSX 10.7.4 Pro Tools Music & Post Operator V6-8, Instructor, and Expert ICON Mixer Certified. Multi-Platinum Pro Tools Videos |
What happens if you use the Mono algo
Denis Mac Pro 3.3 hexacore 24 gb RAM Lion PT 10 HD Native |
personally I don't think it works well for multi mic'd drums either.
But the way I do it is I go through and eliminate all the *analysis* markers and drop them in by hand across the group as a whole. I don't trust the way it puts in analysis markers on some tracks but not others, or at different points in the waveform. I've had the best sound (less phasing) this way, but you have to be very careful about watching out for funny attacks. Of course, with guitars.... if you didn't track a DI and they're distorted you're pretty much SOL b/c trying to figure out where the analysis markers (and subsequent warps) go will be like trying to find a needle in a haystack. |
I use EA on multi-tracked drums all the time. It works really well for me. I am currently working on a session where the drummer played a Kick a little early, fixed it in no time flat and no artifacts. If the drummer is good, pocketing is REALLY easy with it.
Thanks so much for the replies!
I'll be back on the project where this became a big issue tomorrow/well today... I'm going to give it a whirl using the rhythmic algorithm. Has anyone been using EA for multimiced guitars successfully? A side note... I also recorded the DI signal from the guitar and have Eleven... I LOVE IT!!! So worst case scenario I would Elastic Audio those tracks and either send them back out to the amps or use Eleven... BUT! it would be less time consuming if Elastic Audio would work on the miced guitars... Thanks again! David Glenn SpiritWalk Productions/Azmyth Recording Studios [email protected] |
God Bless, David Glenn |
Have you had any luck using EA on multi-miced guitars? Thanks again, David Glenn |
I will definitely give it a test run here soon and let you know if any of the other algorithms work in my situation... Thanks and God Bless, David Glenn |
Elastic Audio on Guitars? | lcphr3ak | General Discussion | 5 | 05-10-2011 01:44 PM |
Need help with Electric Guitars and effects... | whateverwrks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-12-2008 02:09 PM |
Elastic Audio and multi-mic tracks | zakco | Pro Tools TDM Systems (Mac) | 26 | 02-05-2008 10:14 PM |
only1compressor on multi-miced guitar tracks:good? | seth666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-22-2005 05:27 PM |
Condenser mic for electric guitars.... | pedrohead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 04-12-2003 01:04 PM |
