Old 02-11-2009, 01:57 PM
BlueThursday BlueThursday is offline
Default PT8 fresh install
I've searched the forum and while I see hints I can't find an answer to an easy question. Is the boxed version of PT8 LE which is labeled as an upgrade functional as a stand alone version? Can I put it on a Mac that's never had PT on it? It seems that I can based on some references to removing prior versions. But if that's the case, why is it called an upgrade whereas the M powered version (which sells for $100 more) is not called an upgrade?
Old 02-11-2009, 02:22 PM
flommer flommer is offline
Default Re: PT8 fresh install
It is a standalone installer, no previous version needed.
It is just semantics as to weather it should be called an "upgrade" or not..
Since it has a bunch of new features, upgrade is fine with me...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 02-11-2009, 02:42 PM
Thanks.
Any idea why PT8 M-powered is $250 whereas LE is only $150?
Old 02-11-2009, 03:33 PM
Maybe because it is a standalone purchase anyway? IDK
Old 02-12-2009, 09:05 AM
DigiTechSupt's Avatar
Originally Posted by BlueThursday View Post
Thanks.
Where are you reading that? The M-Powered upgrade should be $150, just like LE.
HD, on the other hand, is $250.
Avid Audio Tech Support
Support FAQ
Old 02-12-2009, 12:08 PM
M-powered at $250 from Guitar Center
LE at $150 from Guitar Center
Unless there is a difference that I can't find....
Old 02-12-2009, 02:28 PM
That first link to M-Powered is for the full version installer that includes the iLok key.
The upgrade from a previous version should be $149 - it requires that you have the full version as you have to surrender your previous version iLok license when you upgrade to Pro Tools 8. Here's a link to the upgrade on the Digistore:
Pro Tools M-Powered Upgrade on the Digistore
The second is, indeed, an upgrade to Pro Tools LE 8.
Support FAQ
Old 02-12-2009, 03:31 PM
So is Digi ever going to sell a version of PT8 LE on disc that I can install on a Mac that has never had PT on it? The download doesn't interest me.
I already have PT LE 7.3 on a PC.
Old 02-12-2009, 03:39 PM
I think it is already available at the Digi store, but it costs you $30 extra. I'm not happy about that, either.
I have heard that is is available at resellers, but haven't checked prices..
Old 02-12-2009, 04:59 PM
Flommer is correct on that point - you can get the installer DVD's here:
http://store.digidesign.com/us/index...&categoryid=16
I'm curious - is there a particular reason you're not interested in the download?
Support FAQ
Fresh install...bad, bad, bad.... gofortheheart Windows 5 09-03-2012 03:21 PM
Clean install of PT 10 under fresh install of Lion bortraws macOS 0 10-24-2011 08:53 AM
Fresh install of LE 8 Fezzler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-29-2010 12:13 PM
fresh install halfguard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-08-2008 09:22 AM
How to install fresh OS? BigALW1414 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-20-2004 02:05 PM
