003 rack not connecting
This may be simple mistake on my part but I can't connect to my 003 rack. It worked fine before but now it won't sync to my computer. I was wondering if there is a system reset on the rack itself. I'm pretty sure the only thing I've done differently was updating the Pro Tools software. I'm using OS X 10.4.11 and Windows XP Pro. I can't connect to either OS. I'm really green with Pro Tools too, so I may have done something foolish along the way.
Any tips or suggestions would be great. Thanks. |
Re: 003 rack not connecting
Try a new firewire cable as the factory cable is a cheapo. If you open (on the windows machine)Control Panel>SYSTEM>Device Manager, is the 003 seen as an attached device(with it powered on)?
I'm using the same cable I used before. It's not the original and it's only 5 or 6 feet long. It's not showing up in device manager. The Host light isn't lit either. I've tried both firewire ports on the rack and my PC. Just doesn't show up. I powered up properly, although I'm not sure how important that really is. I did turn the rack on after the computer was already on a while ago. Could that screw something up?
RE: 003 rack not connecting
Have you tried looking at the System Profiler/Firewire tab? The profiler is found in the Applications/Utilities directory.
This will tell you if the Mac can see the 003. It will also tell you what else is using FireWire. I would disconnect all other FireWire devices and power cycle again. I was told by Digi that disconnecting the 003 from the computer is really the only dangerous thing you can do regarding connecting/disconnecting so , yes, powering things up in the wrong order can be bad. -Kent |
Which model Mac are you running?
Is the 'Link' light between the firewire ports on the 003 lighting up? If not - you may have a blown firewire port. Did you possible connect or disconnect the 003 while either the 003 or the computer were turned on? |
Connecting Eleven Rack to Digi 002 Rack | TMitchJobe | Eleven Rack | 12 | 02-02-2013 10:54 AM |
Help Connecting 003 Rack and C|24 | GCSC | ICON & C|24 | 5 | 07-12-2011 11:00 AM |
Connecting Sub to 003 rack | bkwalker510 | General Discussion | 2 | 01-02-2009 12:12 PM |
002 Rack Not Connecting to G5 | majikdragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-20-2008 01:52 PM |
rack not connecting | andymae | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-18-2007 05:14 PM |
