To dither or not to dither...that is the question.
Hello,
If you record at 24/48 and bounce to disc without using a dithering plug in, but however, you select 16/44.1 from the bounce to disc menu, are you in effect dithering? Let me back up....I have usually used either the Digi dither plug or the one that comes with the Waves L1 ultramaximizer. The other day I bounced a quick mix to cd without a dither plug in and just selected 16/44 from the bounce to disc menu and it didn't sound too bad. Which, brought me to this question....What is the difference between using a dither plug in and just selecting 16/44 from the bounce to disc menu (without using a dither plug in). Thanks so much for your time. |
Re: To dither or not to dither...that is the quest
If you BTD without manually inserting a dithering plugin, you'll be truncating.
Cavell Studios |
Thanks...Can you put as easy of a definition on dithering? I think I understand what you mean by truncating.
Thanks |
Cavell Studios |
Thanks a million. I really appreciate it.
Can Dither in Export Prefs be changed to PowR Dither | Mr. Anxiety | Tips & Tricks | 5 | 10-31-2009 10:28 PM |
Dither ... placement of the dither plugin. | tpthai2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-12-2007 07:20 AM |
To Dither or Not to Dither(that is the question) | halipino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-26-2004 11:23 PM |
PT DITHER x masterist dither x TC masterxdither x l1, q10 dither | Alécio Costa | Tips & Tricks | 9 | 02-24-2002 01:28 PM |
Dither or not to dither that is the question! Please help! | roijin | Tips & Tricks | 5 | 05-10-2001 12:05 AM |
