Can 18 Bit Audio Tracks Be Imported Into LE?
I have some old recordings that predate my entry into PT. If I have sessions that were recorded in Cakewalk at 18 bit and I export the wave files, is it possible to import and convert those wave files to 24 bit when I bring them into PT LE?
PT LE 5.1 AMIII Win98SE PIII 450 128 Meg Ram Thanks, bilco |
Re: Can 18 Bit Audio Tracks Be Imported Into LE?
You can import them as 24 bit files, but they will still have 18 bit resolution. The last 6 bits will be "cut off" from the 24 bit file. You can either re-record the tracks at 24 bits or use them as is. Depending on the source material, you probably won't tell a difference. Especially if you can't recreate the source and have no choice
"They may call it walking in Texas, but in California we call it just being a jerk" |
Imported WAV tracks out of sync | Aster | Windows | 6 | 03-15-2014 02:12 PM |
I Imported stereo tracks , but PT reads as 2 L&R Mono tracks ? | Seafoam_Green | Getting Started | 9 | 02-01-2014 09:29 PM |
imported audio won't show up on tracks | JP4 | Pro Tools M-Powered (Win) | 6 | 05-15-2007 02:20 PM |
Low volume on imported aiff audio to tracks | Afrobeatnik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-23-2006 07:36 AM |
how to spread tracks of imported audio | jimlongo | Post - Surround - Video | 9 | 05-01-2006 08:43 AM |
