Old 02-22-2017, 05:23 AM
Annas's Avatar
Annas Annas is offline
Default PT 10HD Physical RAM is running low
Hallo.
have the same problem I read almost all post and tried something to fix current problem, but didn't work.
1. My computer : Macbook Pro, OSX 10.9.5 13-inch, Late 2011
Processor 2.4 GHz Intel Core i5
With two memory slots 2GB, 2GB (4GB)
2. DAW : Pro Tools HD10
Problem is that I'm working on a project in witch i use most Dly, and revers
and when I start working in this project PT says : Physical RAM is running low for better performance install more RAM.
In Playback Engine it was on 512 mb Cache Size and I put it on 1GB, but problem isn't solved PT says the same every time I start working in the same project and this happens in only one project.
H/W Buffer Size : 512 Samples
Host Processors : 4 Processors
CPU Usage Limit : 85%
Seems like everything is ok in the Playback Engine, but it still didn't helped.
after I put it on 1GB Cache Size now PT says: Physical RAM is running low. for better performance, reduce the Disk Cache Size in the Playback Engine or install more RAM.
I have also another problem about CPU when the project is playing it stops and PT says: A CPU overload error occurred. If this happens often, try increasing the ''H/W Buffer Size" in the Playback Engine Dialog, or removing some plug-ins. (-6101)
I would like to solve this problem without removing some plug-ins cause they are not too much and it means that in another project if i'll start using this number of plug-ins I'll got the same as in this project.
Thank you very much for any help <3
Old 02-22-2017, 07:56 AM
Ben Jenssen's Avatar
Default Re: PT 10HD Physical RAM is running low
After you did this 1 of your 4 gb of ram is used for the disk cache.
If you set it to "normal", all 4 gb's will be available for PT.
Old 02-22-2017, 08:06 AM
Annas's Avatar
Thanks for answer :)
Well I tried that also, but didn't help so its seems like changing Cache Size doesn't changes that problem :/ in outputs are also everything ok. So can't find out how to fix it
Old 02-22-2017, 10:01 AM
JFreak's Avatar
JFreak JFreak is online now
You can fix it by installing more memory to the computer
Janne
Old 02-22-2017, 10:30 AM
Annas's Avatar
will that fix also CPU overload problem?
Old 02-25-2017, 09:16 AM
JFreak's Avatar
No. Memory is memory and CPU is CPU
Janne
Old 02-25-2017, 11:51 AM
Annas's Avatar
I'm about to fix overall problem, so it means that installing more memory will help only for physical RAM and About CPU will still have to think what to do.
Old 03-01-2017, 02:28 AM
JFreak's Avatar
Respectively, you can get better processor performance by upgrading the processor (or buying a new computer)
Janne
Old 03-01-2017, 06:43 AM
Annas's Avatar
Somehow helpful answer, but not for this moment I just needed to save my project till i upgrade processor witch i don't know how to do or buying new computer. So I just exported all channels one by one and will bounce them also one by one and then in new session I'll import all of this audios I think and I hope It will help.
Old 03-01-2017, 07:10 AM
tundra
Guest
Posts: n/a
install more ram. 4GB is barely enough to run the OS.. and PT10 can only address 4GB of ram MAX anyways, since its not 64bit.
PT HD 10 physical ram running low? garnoil Post - Surround - Video 16 02-23-2017 05:53 AM
Running 10HD and 11 HD together. SteveGarman macOS 4 06-17-2014 07:58 PM
New Install of 10.3.3: Physical RAM Running Low Immediately dougdude9 Windows 4 02-22-2013 11:26 PM
Physical RAM Running Low Fuzzyc Windows 7 02-18-2013 05:32 PM
Dual Boot 10.6 running 8HD & 10.7 running 10HD STL Audio macOS 3 04-14-2012 05:38 AM
