Old 11-05-2014, 02:04 AM
Oblivion777's Avatar
Oblivion777 Oblivion777 is offline
Default Nugen Visualizer 2 (AAX-DSP, too)
Nugen Audio have released their Visualizer 2 plugin which is either AAX-Native or can be purchased as AAX-DSP as well.
Here's some additional info from Nugen web page
Comprehensive audio analysis
Multiple level meters (Peak/RMS/K12/K14/K20 etc.)
FFT Spectrum Analysis
Stereo Spectrum Analysis
Spectrogram
Stereo Spectrogram
Vector Scope
Stereoscope
Stereo Bias meter
Correlation Meter
Correlation by frequency
Stats and Parameters module
Comparison Mode
Comparison mode allows the direct comparison of two sources within a single Visualizer interface, utilising overlay, side-by-side and differential views. Ideal for examining the difference before and after a mastering signal chain or for comparing spectra in preparation for EQ matching or notching out.
Main DAW: MacPRO 5.1, 8-Core Xeon 2.93GHz, 24 GB RAM, OSX 10.13.6, HDX2, PT2019 Ultimate, 2x UAD-2 Quad Satellites (v9.x) 2x HD I/Os, 1x Omni HD I/O, C|24 Control Surface
Auxilary DAW: MacBook Pro with Retina Display (2012), 2.6GHz quad-core Intel Core i7, 16GB RAM, OSX 10.13.6, PT2019 Ultimate, 1x UAD Apollo Quad Audio Interface /w Thunderbolt Interface (v9.x)
Old 11-05-2014, 03:01 AM
Default Re: Nugen Visualizer 2 (AAX-DSP, too)
Does it do R128 and TP? Can't find any info on the site nor the manual.
If not I'll stick with Insight that came with RX3.
Frank.
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 11-11-2014, 12:28 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Nope. VisLM for that. But it does mean you can have it on your mix bus as a DSP plug and don't have to "enjoy" appalling CPU latency and overheads like in Insight.
It is also very customisable and resizable to any size and that is worth its weight in gold alone! Go try it really is good.
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
Old 11-13-2014, 06:32 PM
friendlybunny friendlybunny is offline
I would purchase if there was a surround version available.
Old 11-14-2014, 12:43 AM
From memory it works in surround.
cheers
BAFTA member
IPS member
HTML code is On
WTB: Nugen ISL TrentWilliams Buy & Sell 0 08-18-2014 12:55 PM
Nugen Audio VISUALIZER Crashing ProTools 11.1.3 DavoBali AAX Plug-ins 12 06-24-2014 08:15 AM
Wtb: Nugen isl TrentWilliams Buy & Sell 0 05-13-2014 07:26 PM
WANTED: Nugen ISL TrentWilliams Buy & Sell 0 10-10-2013 02:22 PM
MIDI Play indicator / visualizer daslicht Pro Tools TDM Systems (Mac) 4 08-29-2009 01:59 AM
