copy midi note from track a to track b without del
How to copy midi notes from track A to track B without deleting notes on track B ?
Hi i've imported a midi file that contain two midi tracks. Now in my PT session i 've two midi tracks : SnareMid and KickMid I would like to have at final only one track that contain the SnareMid notes on C1 and the KickMid notes on C0. How can i do ? I tried to select only the midi notes of the kick on KickMid track (ctrl-shift+click keyboard C0), and then to copy them in the other track, but unfortunately it deletes the note on SnareMid track Plz help, i'm getting mad |
Re: copy midi note from track a to track b without del
Aren't you better to leave kick 'n snare on separate midi tracks - I find it can make arrangement stuff easier. The CPU hit from 2 midi tracks vs 1 midi track would be minimal and copy/paste etc editing of two tracks is about as easy as for 1 track.
Just my 2 cents Cheers, Scott
"...I asked you not to tell me that!" |
All you need to do is use merge paste! Place your cursuror where you want your notes to go and then use alt+m or from your edit menue select merge paste! I do it all the time to consolidate my drum files to save room after I've finished editing them.
Copy Audio Track Automation to Midi track controller (Mod Wheel) | cybercampbell | macOS | 3 | 05-11-2013 10:18 AM |
copy instrument track to midi track | trev1238 | Pro Tools 9 | 5 | 02-04-2012 01:16 AM |
strike will not play a midi note on a track | Filmusic | Virtual Instruments | 2 | 07-30-2010 12:48 AM |
Moving a MIDI note to a new track in PT8 | Oroz | MIDI | 3 | 01-30-2009 11:00 AM |
midi track note view is miniscule | crizdee | Pro Tools TDM Systems (Mac) | 1 | 12-16-2005 07:25 AM |
