Old 05-27-2020, 09:11 AM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
Default ProTools.exe hangs or crashes on close. Every. Single.Time.
Hi Gang,
I have a new PC build - coming from Mac. It's working -ok- but as subject says: ProTools.exe hangs or crashes every single time I close the app. I can't force-close the process (Access Denied). I have to reboot.
I've searched the forum w/o any useful results. I'm hoping someone here can point me in the direction of a solution. Thank you!
Sandra Report:
SiSoftware Sandra
ID
Host Name : BC-Prod-PC
Workgroup : WORKGROUP
Computer
Model : MicroElectronics B744 PowerSpec
Serial Number : B74403*******
Chassis : Default string Desktop
Mainboard : ASUS PRIME Z390-P
Serial Number : 1910598********
BIOS : AMI (OEM) 2606 10/24/2019
TPM - Trusted Platform Module : INTC Intel 2.0 (PCR 24)
Intel vPro : 12.0.39.1431
Total Memory : 31.88GB DIMM DDR4
Processors
Processor : Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz (8C 3.6GHz/4.9GHz, 3.3GHz IMC/4.3GHz, 8x 256kB L2, 12MB L3)
Socket/Slot : FC LGA1151
Chipset
Memory Controller : ASUS Core8S (Coffeelake-S) Host Bridge/DRAM Registers 100MHz, 2x 16GB DIMM DDR4 3.2GHz 128-bit, Integrated Graphics
Memory Module(s)
Memory Module : Crucial/Micron BL8G32C16U4BM8FE1 8GB DDR4 1Rx8 PC4-25600U DDR4-3200 (19-19-19-43 4-62-20-7)
Memory Module : (Bad)/Hynix (Hyundai) NMUD480E86-3200 8GB DDR4 1Rx8 PC4-25600U DDR4-3200 (17-17-17-38 4-58-19-6)
Video System
Monitor/Panel : Dell Computer DELL U3818DW
(3840x1600, 37.5")
Video Adapter : Intel(R) UHD Graphics 630 (24CU 192SP SM6.4 1.2GHz, 768kB L2, 128MB DDR4 6.4GHz 128-bit, Integrated Graphics)
Graphics Processor
OpenCL : Intel(R) UHD Graphics 630 (192SP 24C 1.2GHz, 512kB L2, 12.8GB DDR4 6.4GHz 128-bit, Integrated Graphics)
D3D 11 : Intel(R) UHD Graphics 630 (192SP 24C 1.15GHz/1.2GHz, 768kB L2, 128MB DDR4 6.4GHz 128-bit, Integrated Graphics)
OpenGL : Intel(R) UHD Graphics 630 (192SP 24C 1.15GHz/1.2GHz, 768kB L2, 128MB DDR4 6.4GHz 128-bit, Integrated Graphics)
Storage Devices
Disk : WDC WDS100T2B0C-00PXH0 (1TB, PCIe3x2/NVMe)
Disk : WDC WDBA3V0010BNC-WRSN (1TB, PCIe3x2/NVMe)
Disk : Memorex Mini (32.2GB, USB2)
Logical Storage Devices
Windows (C:) : 931GB (NTFS, 4kB) @ WDC WDS100T2B0C-00PXH0 (1TB, PCIe3x2/NVMe)
Windows RE tools : 400MB (NTFS, 4kB) @ WDC WDS100T2B0C-00PXH0 (1TB, PCIe3x2/NVMe)
BC PC Data (E:) : 931GB (NTFS, 4kB) @ WDC WDBA3V0010BNC-WRSN (1TB, PCIe3x2/NVMe)
BC WAVES (D:) : 30GB (FAT32, 8kB) @ Memorex Mini (32.2GB, USB2)
SYSTEM : 252MB (FAT32, 2kB) @ WDC WDS100T2B0C-00PXH0 (1TB, PCIe3x2/NVMe)
Peripherals
LPC Hub Controller #1 : ASUS Z390 (Cannon Point) LPC/eSPI Controller
Audio Device : ASUS ICH300 (Cannon Point) cAVS
Audio Codec : Realtek Semi High Definition Audio
Disk Controller : ASUS ICH300 (Cannon Point) Shared SRAM
Disk Controller : ASUS ICH300 (Cannon Point) SATA AHCI Controller
Disk Controller : Sandisk Standard NVM Express Controller
USB Controller #1 : ASUS ICH300 (Cannon Point) USB 3.1 xHCI Host Controller
SMBus/i2c Controller #1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft Software Printer Driver (300x300, Colour)
Printer : Microsoft Print To PDF (600x600, Colour)
Biometrics
Voice : Analog NUI Voice Virtual Sensor (Voice)
Peripherals
Media Player : Memorex Mini (29.91GB)
Network Services
Network Adapter : Realtek PCIe GbE Family Controller (Ethernet)
Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet)
Wireless Adapter : Intel(R) Wireless-AC 9461 (802.11ac (VHT), AES-CCMP, 390Mbps)
Operating System
Windows System : Microsoft Windows 10 Professional 10.0.18363
Platform Compliance : x64
Old 05-27-2020, 10:48 AM
sw rec sw rec is offline
Default Re: ProTools.exe hangs or crashes on close. Every. Single.Time.
You didn’t specify what version of Pro Tools you’re trying to run, but in your Sandra report, I see 2 different kinds of RAM. And one set says (bad). Try removing those (bad) and see if that helps. Pro Tools really needs all RAM sticks to be identical. Did you install Pro Tools to the default location, or direct it somewhere else?
Old 05-27-2020, 11:01 AM
A common cause of this (Discussed on DUC many times before) is a bad plugin or a corrupt session.... so trash prefs and test by removing all third party plugins. (EDIT... do this after fixing the obvious RAM problem, if you still have the issue).
Old 05-27-2020, 12:02 PM
Memory Module(s)
Bad RAM and mis-matched RAM??? As said, all RAM should be exactly matched. First step(for me) would be to pull the Hynix RAM and see what happens.
Old 05-28-2020, 10:10 AM
BCnSTL's Avatar
The RAM tests fine. THere are no other issues with PT sessions or any other programs. No anomolies or random crashes *except* when I close Pro Tools.
I'll replace the RAM as a precaution but I do not believe that's the smoking-gun here.
Old 05-28-2020, 11:08 AM
what is this^^^ and why is it formatted as FAT32?
Old 05-28-2020, 10:09 PM
You can move all .aaxplugins out of the plugin folder, trash prefs and restart pro tools and have all that done within a minute or so. So just try it... and the results are?
But... memory tests are notoriously useless at finding corner cases, passing them really does not help... they are very useful when they fail. But that Sandra flagged an issue here, or just that you have mismatching DIMMs is just bad and you should fix anyhow... so great you are doing that.
Old 05-28-2020, 10:19 PM
Likely the UEFI/EFI partition.
Old 05-30-2020, 02:13 PM
BCnSTL's Avatar
I changed my display resolution form 3840x1600 w/scaling @%150 to 2560x1080 w/scaling at %100 - and poof - the the post-close crash seems to have gone.
CPU usage is way down too.
Old 05-30-2020, 02:20 PM
BCnSTL's Avatar
Oh - I’m running PT 2020.5 - I use a bunch of latest WAVES, Toontrack VIs, SoundToys and some ValhallaDSP plugins. Nothing nichey or esoteric. I use an Eleven Rack for audio I/O.
Pro tools hangs on close dobes Pro Tools 2020 3 04-11-2020 04:24 PM
ProTools Crashing every time I close a session drvibb Pro Tools TDM Systems (Mac) 9 02-28-2010 06:08 AM
PT 7.4 cs5 OSx 10.4.11 Protools hangs on session close xxicjoy Pro Tools TDM Systems (Mac) 1 02-25-2009 01:08 PM
Protools free hangs when i close app hat123 Digidesign Hardware & Software 3 07-19-2001 05:10 AM
protools freezes/hangs/crashes/etc after about 20-60mins cazfair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-18-2001 05:57 AM
