Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 12-10-2001, 10:15 PM
Ryan H. Ryan H. is offline
Default Hardware buffer size
I am using a Pentium 4 (cpu 1.5 grtz) with windows 98 -512 ram; When recording a session using 24 bit, I get a hardware buffer size error stating to lower the buffer size. I am only allowed the maximum hardware buffer size of 1024 samples. When I lower the buffer size, the program tells me to increase the buffer size. Does anyone know how to correct this problem? Are Pentiums able to record using 24 bit? Also, I noticed that when I converted the session to 16 bit, I no longer received the error messages.
Ryan H.
Old 12-11-2001, 01:49 AM
peteri peteri is offline
Default Re: Hardware buffer size
I'm actually a Mac user - but my background is PC's so here goes.....
Nope, Pentiums can record any number of bits you want, but as 24 bit files are a lot larger (50%) and reducing the file size gets rid of this error - this could well be a disk access problem (not enough speed).
Few things to check:
1) Do you have DMA access turned on? Go to control panel, system, device manager and double click on the hard drive, this will give you much better access and by default is off.
2) Does this always happen? If not it could be something else kicking in, so in the same place on the CD drive turn off auto-insert notification, this will make sure the CD scan isn't pausing the system for a split second.
3) Make sure you don't have find fast (or any other disk indexing rubbish) scanning the drives
4) Very important - make sure if you have a virus checker that it is turned off when you're doing audio - otherwise it may be checking your audio files when you're reading them and definitely when you're writing them and this will do you no good at all.
Hope this helps
Pete
Hardware buffer size bobmcp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-23-2008 06:29 PM
Getting that HARDWARE BUFFER SIZE with . . . . Elton Hyland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-25-2007 05:26 PM
Hardware buffer size Lasse78 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-21-2006 05:58 PM
Hardware Buffer size jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-01-2006 09:48 PM
Hardware buffer size in relation to DAE buffer sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-04-2006 10:30 AM
