Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 08-18-2013, 12:34 PM
BunX BunX is offline
Default Mbox 2 ASIO driver problems
Hi, I've had my Mbox2 for years and never had any problems with it on my MacBook but I have a project I need to do on a PC laptop (running Windows XP) using Cockos Reaper.
I've installed the latest Windows XP drivers and everything seemed to be working fine; Reaper can see the mbox2 and I can route the inputs and outputs, I can even monitor the inputs but if I try to record (or monitor the output) I get a digital sounding distorted noise. It will record a waveform but as it renders it I can see the wave distorting and it will playback but the noise is totally distorted.
I've tried everything I can think of and it's driving me a bit nutty so I'd be very appreciative if anyone can help me out with this.
Old 08-25-2013, 07:19 AM
Emcha_audio's Avatar
Default Re: Mbox 2 ASIO driver problems
Hi there Bunx, welcome to the forum
Can you post a Sandra report? http://www.sisoftware.co.uk/
Also just to make sure, have you tried a fresh install of everything?
And thirdly is this happening with other daw software?
Manny.
Wave-T.com
ASIO Driver Problems with Sonar 8.0 and FL 8 scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-22-2009 03:43 PM
Asio driver problems with 002 Pro tools 7 with SP2 inka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-03-2007 08:01 PM
ASIO driver problems - CPU straight to 100% Groovr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-21-2007 10:41 PM
asio driver problems headclouds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-29-2005 10:12 AM
Asio driver problems Full Clip 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-08-2003 09:35 AM
