Old 11-10-2012, 09:13 PM
SmokinBaldMonkey SmokinBaldMonkey is offline
Default 2008 Mac Pro has more power than an HDX2 ?
My Mac Pro his an 8-core 3Ghz machine. Its just old enough that I can not migrate to Mountain Lion.
However, I can run 90 tracks with ten instantiations each of the Avid Channel Strip Plugin, and it taxes the CPU at about 40%.
This exact same session maxes out an HDX2.
By extrapolating the numbers, I should be able to expect the Mac Pro to run the same power as an HDX3 with about a 60% load to the CPU.
So Why should I buy an HDX core, if a Mac Pro from 2008 has more power running Native? Whats the benefit?
Veni, Vidi, Funki - I came, I saw, I laid the stank down
System 1: Retina MBP 512SSD/16RAM - Thunderbolt HDX1/HDIO
System 2: Mac Mini - 512SSD/8RAM - Thunderbolt HDX1/HDIO
OSX 10.8.5
Pro Tools 10 HD
Pro Tools 11 HD
SYNC HD
Old 11-11-2012, 12:51 AM
ilulilu888 ilulilu888 is offline
Default Re: 2008 Mac Pro has more power than an HDX2 ?
i have an 2010 8 core Mac pro and HDX 1 .....i can run much more then 90 tracks and a hell lot of plugins ......with out maxing out my system ....you must be doing something wrong on an HDX....no way it maxes out that easily....
Pro Tools 12HD
HDX 1
Avid HD 8x8x8
Avid Omni HD
MacPro 2.4 Xeon 8 core 24Giga
UAD-2 And most of the UAD plugins
All AAX DSP and Native Plugins (all most)
Tons of Hardware...:)
Old 11-11-2012, 03:14 AM
cjguitar cjguitar is offline
Default
Try instantiating 10 instances of Revibe native, that will bring your computer to its knees, yet only take up 5 chips on HDX. Also, at the same time try tracking through several instances of native plugins, and you'll hear some latency. I think the combination of HDX with loads of native plugins is the way to go ultimately.
Chris M. Jacobson, CAS
Re-recording Mixer, Sound Designer
IMDB
Old 11-11-2012, 03:56 AM
Pete Gates Pete Gates is offline
Interestingly, my immediate reaction was "yeah, tell it like it is Chris" so I tried just that on my 8x3.2GHz early 2008 Mac Pro. 10 Revibe II native no problem, 15... no problem, 20... no problem, 25... no problem but I could feel the strain maybe, 30... no go. Not saying HDX isn't worth it for various reasons, I'm considering it, but it does go to show the amazing amount of power available with native (even on a 4 year old Mac!).
Pete
Old 11-11-2012, 05:13 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Default
2 primary reasons -
1. Whatever power you get native - add the HDX power to it. Native + DSP is greater than native alone. 1+1 =2 rather than 1+0 =1. Not just increased plug count power, but higher track count also
2. Ability to track thru and with plugins at a usable latency. I know this has been argued, but no matter which way you slice it DSP is lower latency ESP when the machine gets loaded.
http://www.ainsliegrosser.com/
2013 MacPro 6 x 3.5 32GB OS10.14.4 HDX2 Sonnet Chassis, PT2019.5. Macbook 2018 Watch this to follow mobile mix studio build coming: https://youtu.be/cbqMTjCVj9I
Old 11-11-2012, 05:15 AM
Marsdy Marsdy is offline
I think what gets forgotten in these arguments is that an HDX/TDM system COMBINED with native will ALWAYS be more powerful than native alone... It's not like you loose the power of native on a DSP based system.
Dave Marsden
UK
Long hangs/crashes 11.02 HDX2 fsavell Pro Tools HDX & HD Native Systems (Mac) 1 12-18-2013 04:27 PM
Anybody successfully running a HDX2 on a Mac Pro 8-core Early 2008 Harpertown? Eduardo Apolonia Pro Tools HDX & HD Native Systems (Mac) 7 11-23-2012 12:58 AM
HDX1+96 IO to HD3 and HDX2+96 IO to backup betojapa VENUE Live Sound Systems 4 05-10-2012 05:34 AM
harddisks and HDX2 mr.armadillo Post - Surround - Video 1 04-23-2012 09:46 AM
Can I run HDX2 with two video cards in my Mac Pro? conrad787 Pro Tools HDX & HD Native Systems (Mac) 1 04-22-2012 08:46 AM
