Old 04-22-2009, 03:43 PM
scottthafoo scottthafoo is offline
Default ASIO Driver Problems with Sonar 8.0 and FL 8
I want to find a easier sequencing program to sequence my Roland Fantom MIDI and audio using my MBOX 2. I was using my MPC 2000xl and syncing it but it just caused too much problems with latency.
My first beef is with FL 8. When I select the digidesign audio driver in audio options it says "error creating ASIO drivers." I reinstalled PT, turned my windows sound off and other suggestions that I found on the net. I even reinstalled a diffrent version of FL 8. Same problem, someimes it will say in a paraphrase "Not enough Channels for ASIO, 2 Channels Needed." This is where I'm stuck. I asked all the people at IMAGE LINE but they have no idea...
The same thing in SONAR 8...but this time the driver doesnt even show up in the selection option! Please help...I need to get to making music!
I have MIDI out from my OXYGEN 61 controller to the MIDI in of my sound module. Then I have the soundmodule USB plugged into my computer as MIDI. Then I have the audio out from my fantom to the mbox lines. Do I also need MIDI from the module to the mbox? What else can the problem be???
I have REALTEK sound card..is this y?
Windows Vista Ultimate 32-Bit
Mbox 2
PT LE 7.4
Roland Fantom XR Sound Module
FL8
Reason 4.0
MPC2000XL
ASIO driver problems - CPU straight to 100% Groovr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-21-2007 10:41 PM
asio driver problems headclouds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-29-2005 10:12 AM
Asio driver problems Full Clip 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-08-2003 09:35 AM
asio driver and sonar neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-01-2003 03:29 PM
Cant get asio driver to work w sonar neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-30-2003 11:03 PM
