What's the score with LE 8 and Lion?
Hello.
Are many people happily running LE on Lion, Mountain Lion etc.? I was about to upgrade to PT10 in anticipation of a move to a new MacMini quad, then noticed a few posts where people have cited PT8 was running okay. Wouldn't mind knowing a definitive answer from any happy campers? MBox Mini 2 should still be okay with a new MacMini, albeit ran through a powered USB 2 hub? |
Re: What's the score with LE 8 and Lion?
From my personal experience, and from what I've read on this board, PT8 runs fine on Lion, IF:
You're running PT8 on Snow Leopard, then upgrade to Lion. If you've purchased a computer with Lion or Mountain Lion already installed, and try to install PT8 on it, you will be unsuccessful. (Note: running PT8 on Lion or above will probably result in the loss of midi capabilities.) Others may have different experiences, but I'm running PT8.05 on a MacBook Pro and Mac Mini with no problems. Jim |
Thank you.
I guess a Snow Leopard install on a new machine is then advisable, following the upgrade path as suggested. No MIDI? - so, no MIDI from an Mbox? |
I know I looked into it once but it wasn't possible to downgrade due to the different hardware.....
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION | DESVED | Pro Tools HDX & HD Native Systems (Mac) | 2 | 05-21-2013 03:18 PM |
lion -> mountain lion question | grant howarth | macOS | 3 | 05-01-2013 01:24 PM |
Lion or Mountain Lion for mid-2009 MBP with PT9 | miezurecords | macOS | 0 | 03-17-2013 12:38 AM |
Would you go from Snow Leopard to Lion (not Mountain Lion) if you could? | EricWillhelm | macOS | 9 | 01-11-2013 10:55 AM |
Macbook Pro+lion+PT9 :-( / iMac+Lion+PT9 = :-) | Pehja | macOS | 12 | 11-08-2011 01:27 PM |
