MIDI Input PT 5.1.3
Hey guys,
I've been trying with a number of MIDI devices, but I cannot get any MIDI input in PT. Using a Midiman Midisport 2x2 now, and it's installed properly in OMS - I see the light blinking with midi notes being played, I see it in Pro Tools midi input devices and on the track, but nothing gets recorded or is playing through the track... I know it's been a few years since I've used 5.1.3, but am I missing some stupid critical step to getting MIDI into the program here? I've been at this for a few weeks now with several devices, so I don't think it's the hardware at this point anymore... Thanks for any tips. Sig |
Re: MIDI Input PT 5.1.3
Wow that's going back a long ways. Is the Pro Tools Midi track showing the Midi device's channel number? Is the Midi track set to record?
You may also want to try creating a brand new session from scratch and try again. Sent from my iPhone using Tapatalk
Armando |
Ya, I did all that...it's showing in the track, it's set to input, track record enabled...and I did a brand new session as well.
Totally odd...must be something else wrong... |
Are there any settings in Pro Tools Midi menu in the Finder drop down that may be disabled?
Armando |
OMS is installed, the MIDIsport shows up in Pro Tools...there's also no output of the device either from tracks that have MIDI on them...I even tried 2 different MIDIsport interfaces, same thing with both.
I gotta be missing something else here? |
Ahhhhhhhh in OMS, you have to enable the extra 2 ports for the MIDIsport...it's not enough to just have the device enabled.
Once that's done, the 2 ports PLUS the MIDIsport show up as devices, but you have to select the ports and NOT the device... So convoluted haha. But she works!! Thanks for your help. Sig |
(SOLVED)No MIDI input activity and no sound from VIs - but PT actually records MIDI!? | JohannesR | macOS | 3 | 08-24-2012 07:02 AM |
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input | yellow | Eleven Rack | 1 | 05-04-2012 03:33 PM |
New to MIDI. Input is quantizing. Input Quantize is disabled | LiamSlack | MIDI | 0 | 03-25-2008 08:59 PM |
Midi problem - no INPUT DEVICE option in MIDI menu | tam103 | MIDI | 2 | 01-05-2007 08:01 AM |
USB input versus actual MIDI input | seanhupe | MIDI | 3 | 12-23-2005 07:35 AM |
