Old 03-19-2017, 04:14 PM
derricky derricky is offline
Default WORKFLOW question: Using Stereo Audio Suite on two mono tracks
Hey guys -
I've got a mono VO which i'd like to render, effectively getting the effect of a e.g. pan sweeping from left to right.
I've used two methods and both have different outcomes
METHOD 1
I duplicate the mono clip and place both mono clips into a stereo track, then render it using e.g. PANMAN (soundtoys) or MONDO MOD (waves) to get the stereo sweep. this method works as I'd want it - hearing the stereo sweep from e.g. left to right
METHOD 2
I create two mono tracks, hard pan them left and right respectively then place the clip onto one mono track and duplicating that clip placing it into the other mono track. hitting play would give me effectively a dead centre VO. doing the same audiosuite process above, and rendering it, creates an wet processed VO however, the pan doesnt' sweep left and right.
I'd like Method 2 to mimic Method 1. is this possible or not?
Old 03-20-2017, 12:37 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: WORKFLOW question: Using Stereo Audio Suite on two mono tracks
Why do you try to do it the hard way? Can't you insert a realtime plugin and automate what you want it to do? You could then print the track if you want to disable the plugin, but even then your settings and automation is preserved and should you need to you can modify it later.
Janne
splitting stereo tracks to mono -- audio quality? mcconnellsteve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 04-10-2023 09:45 AM
Mono tracks vs stereo track, ø comparison, audio suite midnightrambler Pro Tools 12 14 08-30-2016 02:41 PM
Audio import on stereo tracks instead of dual mono ? vudoo Pro Tools 11 9 06-14-2016 03:25 AM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
Question - Can I combine two mono tracks to a stereo? tendb Tips & Tricks 1 04-04-2007 08:51 AM
