bugged by switching to latch
have discovered the joys of preview for snap shotting a scene roughly - doing a dialog premix for a foreign language version. ( have to thank Mike for his very useful tutorial )
technique= turn off the N for iNsertion follows playback. create range. hit preview on the automation window. tweak until rough EQ/ verb sends are in ball park. capture and manual write.. read the warning ( that N key is close to nudge keys eh? ) but am struggling - becos I am finding using preview or not. my automation is switching to latch mode. have tried the prefs - after pass switch to touch or unchanged. any advice? is this a known thing? signature has my set up in it thanks
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive Focusrite Saffire PRO 40 Ultimate 2022 10 / HD Avid MC Mix / MC Control |
Re: bugged by switching to latch
That is unfortunately specifically only for pass with the automation mode set to "write".
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
ah thanks! thats a fiddly pref.
anyways luckily I have artist control and mix if I assign soft key to turn on preview and capture - then manual write. then the problem goes away - its also faster... so win win - I just find programming the Eucon stuff so slow... and hard to rejig.. seems its only if I use the command num pad 4 automation that the issue bites.
Touch/Latch - Preview - Ends up in Latch? | YMAaron | Post - Surround - Video | 3 | 07-19-2016 04:11 PM |
Automation: touch/latch changes to latch | ha2dorff | Pro Tools 12 | 2 | 09-24-2015 04:38 PM |
PT 11 - MIDI seriously bugged | phoenixsoap | Pro Tools 11 | 0 | 02-08-2014 04:35 PM |
Switching to Latch mode after AutoWrite... | GVDB | Pro Tools TDM Systems (Mac) | 1 | 08-26-2004 01:28 PM |
bugged out 6.4 | dragnfli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-07-2004 01:46 PM |
