DAE Errors 9019 & 9073 PT6.4 LE
Hello:
I Deeply appreciate any help I can get to address my PT problems. Thank You. If appropriate feel free to email me at: [email protected] Out of the blue, after using 6.1 LE for several weeks without incident, My PC started kicking out DAE Errors 9019 & 9073. BtW, Rail Jon Rogut, helped me set this system up some years ago. He had me basically strip down the Gateway PC of unneeded hardware and gave me the PC configuration. So: 1.The errors occur when I pull up a prerecorded .pts file and hit the "Start" button. 2.The system Freezes and a few seconds later i will get the 9019 or 9073 message. Can't exit PT until after a few try's 3.Didn't add any software or make changes to my PC configuration. 4. Searched the DUC and read the trouble shooting and checked system requirements & compatibility matrix & configuration guides. Then made changes as were suggested. I believe all hardware & software to be compatible. 5. Disabled hyper-threading 6.Tested again. Same result 7. Defragged Internal C; drive 8. Defragged external Glyph drive 9.Added 2M ram, 10.Up-graded to PT 6.4LE and 6.4cS9 11. Another try, same result. 12. Loaded Sandra. received message that it would not run with XP service pack 1. So I up-graded to XP service pack 3. 13. Ran Sandra successfully. 14. Always performed the recommended restarts after any changes were made, and then opened PT. 15. Also, randomly get the "no disk in drive" error. Checked the BIOS 1st priority HDD 2nd priority DVD 3rd Priority IBA GE Slot 4th Priority Floppy drive 16. Other than PT, all programs run as expected. 17. System is NOT connected to the Internet and is NOT running any anti-virus software. Current drive stats: C:/ Internal - 149GB capacity - 25GB used. This drive has OS & programs I B/U .pts file copies here also d:/ External Glyph net drive (firewire) 115GB capacity - 6GB used this drive is where I record and save to. * MAYBE IMPORTANT: Sandra report indicates PT6.1 LE. When I open PT it indicates PT 6.4 LE. Deeply appreciate any help I can get. Thank You. [email protected] ---------------------------------- SiSoftware Sandra ID Host Name : protoolsmachine Workgroup : MSHOME Computer Model : Gateway E-6100 Serial Number : 0031592631 Chassis : Gateway Desktop Mainboard : Intel D875PBZ Serial Number : AZBZ32007817 BIOS : Intel BZ87510A.15A.0057.P04.0304280920 04/28/2003 Total Memory : 2.5GB DIMM DDR Processors Processor : Intel(R) Pentium(R) 4 CPU 2.80GHz (2.8GHz/2.8GHz, 2x 512kB L2) Chipset Memory Controller : Intel 82875P,E7210 Memory Controller Hub 4x 200MHz (800MHz) FSB, 2x 1.25GB DIMM DDR 2x 200MHz (400MHz) Memory Module(s) Memory Module : Infineon (Siemens) 64D32300GU5B 256MB DDR PC1-3200U DDR1-400 (3-3-3-8 2-11-0-0) Memory Module : Crucial CT12864Z40BY16TY 1GB DDR PC1-3200U DDR1-400 (3-3-3-8 2-11-0-0) Memory Module : Infineon (Siemens) 64D32300GU5B 256MB DDR PC1-3200U DDR1-400 (3-3-3-8 2-11-0-0) Memory Module : Crucial CT12864Z40BY16TY 1GB DDR PC1-3200U DDR1-400 (3-3-3-8 2-11-0-0) Video System Video Adapter : NVIDIA GeForce4 Ti 4200 (Microsoft Corporation) (AGP 2.00) Graphics Processor Storage Devices Seagate ST3160023AS (160GB, SATA150, 3.5", 8MB Cache) : 149GB (C:) IBM IC35L120AVV207-0 (123.5GB, FireWire/1394, 3.5", 7200rpm) : 115GB (D:) SanDisk Cruzer (2GB, USB2) : 2GB (J:) IOI Media Bay CF (USB1) : N/A (E:) IOI Media Bay MS (USB1) : N/A (F:) IOI Media Bay MMC/SD (USB1) : N/A (G:) IOI Media Bay SM (USB1) : N/A (H:) HL-DT-ST DVDRAM GMA-4020B (462.5MB, ATAPI, DVD-RW, CD-RW, 1MB Cache) : 441MB (I:) Logical Storage Devices Hard Disk (C:) : 149GB (NTFS) @ Seagate ST3160023AS (160GB, SATA150, 3.5", 8MB Cache) Pro Tools LE 6.1 (I:) : 441MB (CDFS) @ HL-DT-ST DVDRAM GMA-4020B (462.5MB, ATAPI, DVD-RW, CD-RW, 1MB Cache) Floppy Disk (A:) : N/A New Volume (D:) : 115GB (NTFS) @ IBM IC35L120AVV207-0 (123.5GB, FireWire/1394, 3.5", 7200rpm) Removable Drive (J:) : 2GB (FAT32) @ SanDisk Cruzer (2GB, USB2) Removable Drive (E:) : N/A @ IOI Media Bay CF (USB1) Removable Drive (F:) : N/A @ IOI Media Bay MS (USB1) Removable Drive (G:) : N/A @ IOI Media Bay MMC/SD (USB1) Removable Drive (H:) : N/A @ IOI Media Bay SM (USB1) Peripherals LPC Hub Controller 1 : Intel 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge LPC Legacy Controller 1 : T0 F0-D1 Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Gateway 2000 82801EB/ER (ICH5/ICH5R) EIDE Controller Disk Controller : Gateway 2000 82801EB (ICH5) SATA Controller USB Controller 1 : Gateway 2000 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 USB Controller 2 : Gateway 2000 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 USB Controller 3 : Gateway 2000 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 USB Controller 4 : Gateway 2000 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 USB Controller 5 : Gateway 2000 82801EB/ER (ICH5/ICH5R) USB 2.0 EHCI Controller FireWire/1394 Controller 1 : Avlab Technology VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Network Services Operating System Windows System : Microsoft Windows XP Home 5.01.2600 (Service Pack 2) Platform Compliance : x86
PT 7.0 Digi 002 Gateway w/ P4 2.8 Ghz XP Home SP1 2.5 Dram - Glyph Net drive 7200 Rpm |
Re: DAE Errors 9019 & 9073 PT6.4 LE
* Well I've got a temporary fix. Now what's my next move? I moved one of the PT Files/songs from the external D:' Glyph net drive and sent it to the C:/ internal drive. It played and everything seems to work on that one. Now, do i back-up all of the D:/ drive and reformat? Suggestions are welcomed and encouraged.
After moving songs to internal drive C:/ I was able to playback no problems for about 2 days. Now I'm back to DAE errors 9019-9073 Help is appreciated
I can see the crowd of company flacks rushing in to help you. They'll arrive virtually any minute (or decade) now.
Lemme spell it out: They don't care. Not one whit. They Just Don't Care. |
9073 and 9019 errors | kevon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 02-23-2011 12:56 PM |
9019 and 9073 errors? | HDK_Ent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-04-2010 04:05 PM |
5.3.1 DAE ERRORS -9019, -9073 | charliebeans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-06-2005 12:08 PM |
DAE Errors 9073 & 9019 | shoalbilly | Digidesign Hardware & Software | 2 | 11-29-2004 09:07 AM |
9019 and 9073 errors | juice | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-03-2003 02:12 PM |
