#21
Re: I am so done with resetting my buffer every 5 minutes (AAE error -9173)
I'm using the new avid plugs in 11 too and they work great. Lol
#22
Dragging from Windows file explorer or desktop to the Pro Tools edit window.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#23
Hi Matt, yes it appears running as admin stops you drag n dropping from file explorer. I wonder why..? It works when not running as admin. I drag drop from the workspace window, which runs fine as admin so no biggie for me but thanks for pointing it out, may affect some users.
#24
Thanks for checking. It certainly is weird. However, I personally haven't encountered any problems with running PT as non-admin since the PT10 days. Not that I use drag-and-drop often, but it's good to have.
#25
OP, did you try Sounddesicions suggestion? |
#26
It's been this way through 10/11 and now 12. I do wish Avid would fix it. |
#27
This is ridiculous. Went from 12.4 to 12.5 last night and I have now lost almost a full day of recording because I get the 9173 error. I had to go back to a restore point in Windows 7 and now PT 12.4 just hangs at opening... so I tried a repair and it still hangs. The darn software just won't open.
Update 1: I now get a ProToolsQuickTimeServer.exe has stopped working message as I try to load PT. It then takes about 10 minutes for PT to load... any clues? Update 2: Got fed up with this. Completely uninstalled PT, cleaned up the registry and reinstalled 12.4 and all is back to normal. What is wrong with 12.5??? Last edited by dramis; 04-22-2016 at 11:29 AM. |
#28
#29
Just a reminder... Clear all cache's run verify drive then permissions if all is well.
If runing SSD drives, check that trim is engaged. (Link to what I shows the difference)
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
PT 11 Clearly Not An AAE 9173 Error | rgconrad1 | Pro Tools 11 | 3 | 09-29-2014 11:56 PM |
H/W Buffer Size keeps resetting to 512 | justbradford | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-23-2009 08:19 AM |
Can't go ten minutes w/out buffer error!! | marc_c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 30 | 07-09-2004 07:59 AM |
Buffer?CPU keeps resetting to 65%, why? | H-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-01-2001 12:38 AM |
