Old 08-05-2011, 02:49 PM
Marcel Risberg's Avatar
Marcel Risberg Marcel Risberg is offline
Default How to bus a multi channel track to a stereo track
Due to the current bounce to QuickTime-bug I need to bus my 5.1 master aux with the Neurinck SoundCode Stereo plug inserted to a stereo track from which I then can use for my bouncing. Otherwise I'm not able to bounce to QuickTime at all.
I can't figure out how to creat this kind of bus, going from 5.1 to stereo. The other way around was never problem.. Does anyone know?
Old 08-05-2011, 03:29 PM
Craig F Craig F is offline
Default Re: How to bus a multi channel track to a stereo track
make a LR subpath in the 5.1 bus you are using
make the input of the record track the LR subpath bus
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 08-05-2011, 03:34 PM
postprosound postprosound is online now
No, you can't directly send a multi channel higher than stereo to a stereo. This is one of those things i would love to see AVID do.
The only way to do it with out a plugin, and call it old fashioned, is to bus your 5.1 aux to another 'record' 5.1 bus. Create 6 mono aux's, L C R Ls Rs Lfe, with the inputs routed to the individual stems of your 'record' 5.1 bus. Output these 6 to a stereo.. Pan tracks accordingly, and drop the C -3db and the surrounds -6 db each. (I think my numbers are correct, correct me if i'm wrong...)
We, in post sound, are illusionists, not magicians.
Old 08-05-2011, 03:45 PM
Maskeeper Maskeeper is offline
But he says he has the plugin... so it should send out the L/R channels of the 5.1 (requiring subpath) or convert the bus to stereo on insertion (depending on the version).
VT
Supervising Sound Editor - Los Angeles
Old 08-08-2011, 01:20 AM
SDDP SDDP is offline
Not to jack the thread, although I am probably still in the are of the op.
Can bouncing to a quicktime and making a Stereo from 5.1 using WAVES M360° Surround Mixdown?
Old 08-08-2011, 06:03 AM
craig is right. simply add a stereo sub path to your 5.1 bus coming from the plugin and use the sub path when bouncing to QT.
the output of the plug will only have signals on L/R anyway so no need to split up all the 5.1 channels. one stereo sub-path will do.
frank.
PTHDn 2019.10 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 08-09-2011, 02:59 AM
TAFF TAFF is offline
+1 on Craigs answer. I've got exactly the same setup. We slap the Neyrinck on the 5.1 printmaster stem. Make a stereo subpath and then bus out of that to a new stereo record track.
Taff
www.bangpostproduction.com
Old 08-09-2011, 05:20 AM
Finally I was able to bounce a stereo submix to QuickTime using a separate recording bus, unaffected by any inserts.
I had to try quite a few different options before I was successful. Also, I ran into a few errors/bugs on my way. To bad this forum doesn't accept picture uploads. I kept a few screen shots of them I wanted to upload.
Thank you for your help!
Old 08-11-2011, 06:51 PM
free Photobucket.com account then post the links
Thank you,
Craig
HTML code is On
Does 10 still have the bug if Input Monitor is on a multi-channel track Craig F Pro Tools 10 0 05-05-2012 07:17 PM
Multi-Mono Trim Plug-In on Stereo Track? Napping Pro Tools 10 1 02-06-2012 09:48 AM
Stereo Aux Track only receiving left channel DRI 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-26-2011 11:59 AM
Turntable to Digidesign 003. I only get half a channel of audio with a stereo track? ninja pro-tools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-09-2008 10:18 PM
Stereo Track Help Please - Pnly Getting Left Channel JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-06-2007 11:38 AM
