#101
Re: Engineer is giving my band information, IS IT THE TRUTH??
Brilliant!!!!!!!!!!!
Pro Tools Tutorials: Mixing Heavy Rock & Metal Pro Tools 11 - Tips and Tricks Delay Explained Tracking Rock - Drums Mixing Rock Music Production with Pro Tools Pro Tools Tips and Tricks Vol. 2 Pro Tools Tips and Tricks Vol. 3 Elastic Audio in Action |
#102
#103
Feels like bad karma. Petty. If I produce and mix a project I just hand in everything. The chances of the label having all my plugins (and summing box) are pretty small. If they want to use an outside mixer they'll usually tell me so I can prep the files for that mixer. They usually prefer a flat mix. No plugins, automation etc. If it's just a mixing gig, I send them the stereo master and keep the Pro Tools file. They already have the session from the Producer.
#104
Then import just the audio tracks (don't need auxes and masters) from your mix session but don't include plugins, sends, volume automation etc. You then have a raw tracks master. Might want to keep the pans though.
#105
or something like that i consolidate the tracks right into the audio folder open the audio files folder view by date then color them red and drop them into a folder and hand it to the client. done deal i'll never need to open that session file version again...bingo.
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
#106
I should get an intern to fix messes like that... In the meantime the clients I can't convince to record everything here I insist on bringing everything they can for me to prepare by hand. Seeing other people's mixing habits is more or less a freakshow to me...eeeewwwww is what I tend to say the most. |
#107
it takes less than 5 minutes the rest is burn and walk away
#108
I'm talking about being on the receiving end of "burn and walk away".
To be utterly clear, I want from the client EVERYTHING THEY'VE GOT. And they should ask for everything as well from whoever they are working with. That includes whatever state of the working session file was current. Ideally, I will even have their computer's startup drive! Basically NO ONE other than a pro mixer knows how to prepare a session for mixing. They don't know when they are printing effects, printing trims, printing bad edits, nothing. They don't even have the ability to hear what they are doing. I have learned to assume total ignorance and incompetence and I have yet to be proven wrong. And to be clear to the OP, this does NOT mean I want someone else's mixing doodles. I'm saying I would want everything you sent to the other mixer (and possibly more, if you "simiplified" or "consolidated" anything for them). |
#109
that's not what i was talking about i was talking about giving back whole files to clients but no session files. roll on.:rolley es:
#110
So you are saying that as a producer/engineer you're giving the clients final edits as consolidated audio and no session data. Which means that they have no means of changing anything without going through you. Then presumably the clients go to some other mixer to have them mixed. In that case I'd rather as a mixer to work with the producer directly. Or maybe you're saying as mixer you're giving them consolidated multitrack audio? Why would they want that...that's just another form of what they handed you. Are you talking about stems? Oh if you are both the producer and the mixer and you are giving them consolidated multitrack audio for safekeeping or something then I guess it makes vague sense. One hopes you have an excellent naming convention though (for scribble strips, Title Case Is The Best Standard!!!, BUT MANY IDIOTS USE ALL CAPS and a lot of other morons think they're cool using all lowercase). |
The Truth of it All? | Diccer | Pro Tools 10 | 24 | 11-16-2011 04:26 PM |
Is there any truth that... | soundboy35 | Pro Tools TDM Systems (Mac) | 22 | 07-25-2007 05:38 AM |
Please HELP! Tell me the truth | funeral | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-20-2007 04:55 PM |
Digidesign giving out your private information to 3rd parties | confusionboats | General Discussion | 15 | 08-29-2002 11:56 AM |
all we want is the truth! | electrobank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 07-19-2000 02:04 PM |
