Midi Looping
Im synching Pro tools and studio vision. Pro tools is master. Im using an OMS IAC bus. Can you set a loop in pro tools and have vision read and play back the same loop?
I cant figure it out. |
Re: Midi Looping
Aha! I see, it has to do with the sdfjmcvfjore and the oeirtjmver....
Re: Midi Looping
Actually, the oeirtjmver has much more to do with the qweignalsd... not so much the
sdfjmcvfjore. It's been awhile since I switched from SVP to Logic, but I don't think SVP will do that. Seems like it has something to do with the continuous feed of whatever sort of code it is that PT sends down the IAC bus. At least SVP will sort of lock to PT... Logic won't. Hopefully Digi will get the MIDI side of PT up to speed soon. Sure would be great to do everything all together. Later, Brian
Brian Steckler, Producer |
Looping a MIDI Clip in PT 10 | Cutlerbri | macOS | 1 | 01-22-2012 11:12 AM |
Recording MIDI - Looping | krazylain | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-27-2007 12:34 PM |
looping midi problems | PiR EmpirE | Pro Tools M-Powered (Mac) | 0 | 09-20-2007 11:24 AM |
Midi Looping | Flpalla | Pro Tools M-Powered (Win) | 3 | 03-07-2007 01:21 PM |
MIDI Looping Problem, Help!!! | DeNiro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-22-2006 09:34 PM |
