Old 08-25-2017, 03:50 AM
TNM TNM is online now
Default HDX and HD 44.1 and 48k in and out latency?
Hi, all the figures on avid's site are for 96k. I don't know why they won't provide figures for lower sample rates.. Using a ton of outboard digital midi gear, there literally is zero point in me using 96k when composing.. 96 k is not going to do anything for an old 31k rompler for example.. yes i have a couple analogs where it would be beneficial but not worth the overall overhead until i get a more powerful mac.
I have been using an apollo system with PT vanilla so i can monitor everything of my outboard in realtime, avoiding the PT mixer and going through UAD fx.
I am now tired of the 32 input limit and the only way to move on from this is HD.
Either hd native with an avid or 3rd party (i.e antelope) hd compatible interface, or a HDX system.
Now, what i would like to know is the latencies of monitoring through pro tools for both these, at the lower sample rates. Let's just use avid interface figures as 3rd party i/o will have different but negligible converter latency. But for sake of uniformity and ease, let's use avid for this example.
The other thing is, someone told me that each plug in instance in HDX adds latency to the monitoring path. Is this true or not? They told me it's the case even with zero latency plugins. If so, the apollo is a superior system and a shame i can't use 64 ins. And if so, to get the HD software, i might get a hd thunderbolt native, and buy an antelope orion HD to connect to it, which like the apollo has it's own dsp mixer with fx, so even in PT hd i could totally avoid monitoring through pro tools. Antelope has a special pdc driver that lines up sample accurately when you record through it with PT HD... it's very impressive when watching the video.
Thanks in advance!!
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX
Old 08-25-2017, 06:38 AM
Default Re: HDX and HD 44.1 and 48k in and out latency?
Wow it seems there is no way to contact avid support to ask them this without an active service plan or paying for an incident? Isn't there a pre sale place for home users that have upgrade questions? Weird!
Old 08-25-2017, 07:40 AM
JoelG's Avatar
JoelG JoelG is offline
Here's the HDX specs: http://www.avid.com/products/pro-too...specifications
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 08-25-2017, 07:47 AM
Originally Posted by TNM View Post
...someone told me that each plug in instance in HDX adds latency to the monitoring path. Is this true or not?...
Not if they're AAX DSP.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 08-25-2017, 08:35 AM
Originally Posted by JoelG View Post
Now I really am convinced people don't even read topic headers...
Those specs only tell 96k, which was an entire point i made in my post, as well as topic header.
Old 08-25-2017, 08:37 AM
Is there a reason avid won't disclose the RTL at 44 and 48K? This is getting a bit suspect. I do NOT believe everyone with a HD native and upwards uses 96K.
Old 08-25-2017, 08:51 AM
interesting..
did aax dsp change from previous hd?
here the moderator says each dsp plugin adds it's own latency
http://duc.avid.com/showpost.php?p=2212247&postcount=2
Also, as you can see in that topic asking the same question 3 years back, no one answered..
Such a shame that no one with HD native or HDX will get the figures.
Low latency mode in HD native is of no use to me cause you can't use fx monitoring.. However with an antelope interface it might work out cause antelope have their own mixer with dsp effects.
If AAX dsp does NOT add latency into the monitoring path, that is a HUGE boon for me and HDX starts becoming more interesting.
Really, with HDX i could replace entire outboard mixers and use pro tools AS the mixer for everything.. integration would be great.. and personally, many of those aax native (and dsp plugins) are just as good as any uad plugin.. take plug in alliance bx room for example, it's an incredible reverb.
EDIT:
ok, it's unusable for me..
3x 3rd party dsp plugins in the monitoring chain would add 4ms latency! WOW!
http://duc.avid.com/showthread.php?t=381002
The point of HDX to me is not having to bounce to audio! Well one of the points!
Does it at least do ADC on the live inputs that you monitor with DSP FX, so it plays back with rest of project in sync?
But even monitoring through an eq, comp and verb would cause monitoring latency issues at 44.1 and 48k
In fact, since there are many true 0 latency native plugins, i think a hd native at 32 samples would have less latency when monitoring with multiple plugins!
Old 08-25-2017, 10:14 AM
JoelG's Avatar
Actually, it was that I didn't read the addendum at the end of the article I posted..
Sorry.
Joel
Jam Space:
Home:
Rig:
Old 08-25-2017, 12:25 PM
Sorry.
Joel
no need, i was just frustrated, i am actually the one who is sorry for snapping. Uncalled for. please accept my apology.
Old 08-25-2017, 05:21 PM
Extreme Mixing Extreme Mixing is offline
Seems like you know everything already anyway...
But this is a time when you really need to talk to a knowledgeable sales rep, or get to know someone at Avid. I can assure you that an HDX System with Avid converters is superior to an Apollo interface. It's expensive, but not without reason. I've never had anyone complain about latency on an HDX System unless you have high latency plugs on the stereo bus.
Steve Shepherd
Extreme Mixing
MIDI recorded latency after playing with no latency genebackmusic Pro Tools 12 8 01-19-2016 02:36 PM
Automation latency when using plugins that have long latency pyrodave Pro Tools 11 2 01-27-2014 11:22 AM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
Latency Issues - changing latency has no effect Kippa-Dee Pro Tools M-Powered (Win) 1 07-15-2010 08:39 PM
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? Mt.Everest Pro Tools TDM Systems (Mac) 7 08-26-2001 04:53 PM
