Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 08-24-2013, 06:46 AM
PT user PT user is offline
Default Re: anyone using PT native hackintosh with sr-2 motherboard?
hi
As the hack was done before I got the machine - I dont have the stick - i guess i could create one?
Sounds like you feel this machine could still get its act together?
Old 08-24-2013, 06:47 AM
Meads Meads is offline
Definitely. If it gets as far as the Apple screen, it means everything's good to go except one little adjustment. We just have to figure out, what it is. And we will.
Before all else, try boot up using the following:
-v -x PCIRootUID=0 GraphicsEnabler=No
if this doesn't work try
-v -x PCIRootUID=0 GraphicsEnabler=Yes
Let me know what happens.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 08-24-2013, 07:34 AM
Hi
Just tried the first one
should it just boot after? or is a restart required (it does say mac framework successfully initialised
Old 08-24-2013, 07:41 AM
tried both - get the the bottom of all the info -nothing - restart - still stuck on apple ...
Old 08-24-2013, 07:52 AM
So the last thing you're seeing is "mac framework successfully initialised", then the Apple screen, then freeze? Do you get the spinning icon below the Apple?
Okay, you should create a bootable usb drive using Unibeast.
Follow these instructions:
http://www.tonymacx86.com/61-unibeas...-based-pc.html
Once you're done, boot from the stick. You should then be asked, which partition you want to use. Choose not the stick, but your system drive.
Let me know, what happens.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
  #16
Old 08-24-2013, 07:54 AM
no spinning icon - it just remains on apple...
I will sort out a stick and set this up ....will be back
thank u
  #17
All right, I'll be around.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
  #18
Old 08-24-2013, 07:55 AM
just clicked on the link - I will need to re-purchase ML by the looks of it
  #19
Old 08-24-2013, 07:57 AM
Are you on a windows computer now?
If you're on a Mac and you already bought ML with your Apple-ID, you won't need to rebuy it.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
  #20
Old 08-24-2013, 08:09 AM
my laptop came with ml. I dont mind repaying - presumably i can nominate where it gets installed? normally it auto installs on the computers system drive doesnt it?
Hackintosh and HD native + 11 Markk Pro Tools HDX & HD Native Systems (Mac) 20 07-30-2013 08:49 AM
Hackintosh with Pro Tools HD 2 fatcode Buy & Sell 0 10-18-2012 05:23 PM
Hackintosh with PT9 HD Native? PMedia macOS 9 07-11-2011 09:12 AM
Hackintosh on my rig? Raoul23 Pro Tools TDM Systems (Win) 7 07-01-2011 03:26 PM
Hackintosh Help HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-16-2010 10:45 AM
