Re: Custom pc build
heres my sandra report..
SiSoftware Sandra ID Host Name : vinny-PC Workgroup : WORKGROUP Computer Model : OEM System Product Name Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS RAMPAGE IV EXTREME Serial Number : 1302079******** BIOS : AMI (OEM) 3602 03/15/2013 Total Memory : 32GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-3970X CPU @ 3.50GHz (6C 12T 4GHz/5.7GHz, 4GHz IMC, 6x 256kB L2, 15MB L3) Socket/Slot : FC LGA2011 Chipset Memory Controller : ASUS Core DMI2 (Sandy Bridge-E) 100MHz Memory Controller : ASUS Core (Sandy Bridge-E) Integrated Memory Controller Registers 100MHz, 4x 8GB DIMM DDR3 1.6GHz 256-bit Memory Module(s) Memory Module : Corsair CMD32GX3M4A1600C9 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-33-10-5) Memory Module : Corsair CMD32GX3M4A1600C9 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-33-10-5) Memory Module : Corsair CMD32GX3M4A1600C9 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-33-10-5) Memory Module : Corsair CMD32GX3M4A1600C9 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-33-10-5) Video System Monitor/Panel : PKB Maestro 242DX (1920x1080, 23.4") Monitor/Panel : Dell Computer DELL E248WFP (1920x1200, 24.0") Video Adapter : NVIDIA Quadro 2000 (4CU 192SP SM5.0 1.25GHz, 256kB L2, 1GB 2.61GHz 128-bit, PCIe 2.00 x16) Video Adapter : NVIDIA Quadro 2000 (4CU 192SP SM5.0 1.25GHz, 256kB L2, 1GB 2.61GHz 128-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA Quadro 2000 (192SP 4C 1.25GHz, 256kB L2, 1GB 2.61GHz 128-bit) Compute Shader Processor : NVIDIA Quadro 2000 (192SP 4C 1.25GHz, 256kB L2, 1GB 2.61GHz 128-bit) CUDA GP Processor : NVIDIA Quadro 2000 (192SP 4C 1.25GHz, 256kB L2, 1GB 2.61GHz 128-bit) Storage Devices Seagate ST3500630AS (500.1GB, SATA300, 3.5", 16MB Cache) : 466GB (C:) Seagate ST3500630AS (500.1GB, SATA300, 3.5", 16MB Cache) : 466GB (D:) WDC WD7501AALS-00E3A0 (750.2GB, SATA300, 3.5", 7200rpm, 32MB Cache) : 699GB (G:) TSSTcorpDVD-ROM TS-H353B (SATA150, DVD+-R, CD-R, 198kB Cache) : N/A (E:) PLDS BD-RE DH-4B1S (SATA150, BD-RE, DVD+-RW, CD-RW, 16MB Cache) : N/A (F:) PHILIPS SPD3100L (USB2) : N/A (H:) Logical Storage Devices Hard Disk (C:) : 466GB (NTFS) @ Seagate ST3500630AS (500.1GB, SATA300, 3.5", 16MB Cache) PRO TOOLS (D:) : 466GB (NTFS) @ Seagate ST3500630AS (500.1GB, SATA300, 3.5", 16MB Cache) SAMPLES (G:) : 699GB (NTFS) @ WDC WD7501AALS-00E3A0 (750.2GB, SATA300, 3.5", 7200rpm, 32MB Cache) Optical Drive (E:) : N/A @ TSSTcorpDVD-ROM TS-H353B (SATA150, DVD+-R, CD-R, 198kB Cache) Optical Drive (F:) : N/A @ PLDS BD-RE DH-4B1S (SATA150, BD-RE, DVD+-RW, CD-RW, 16MB Cache) Optical Drive (H:) : N/A @ PHILIPS SPD3100L (USB2) Peripherals LPC Hub Controller 1 : ASUS Patsburg LPC Controller LPC Legacy Controller 1 : T0 C3-33 Audio Device : ASUS Patsburg High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : HP GF106 High Definition Audio Controller Audio Codec : nVidia 0011 Audio Codec : 1 0001 Audio Codec : 1 0001 Disk Controller : ASUS Patsburg 6 Port SATA AHCI Controller Disk Controller : ASUS Asmedia 106x SATA Controller Disk Controller : ASUS Asmedia 106x SATA Controller USB Controller 1 : ASUS Patsburg USB2 Enhanced Host Controller #2 USB Controller 2 : ASUS Patsburg USB2 Enhanced Host Controller #1 USB Controller 3 : ASUS ASMedia XHCI Controller USB Controller 4 : ASUS ASMedia XHCI Controller USB Controller 5 : ASUS ASMedia XHCI Controller USB Controller 6 : ASUS ASMedia XHCI Controller SMBus/i2c Controller 1 : Intel ICH SMBus SMBus/i2c Controller 2 : Intel SNB-E XMB Ch 0 SMBus SMBus/i2c Controller 3 : Intel SNB-E XMB Ch 1 SMBus Network Services Network Adapter : Intel(R) 82579V Gigabit Network Connection (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
Re: Custom pc build
Re: Custom pc build
thanks for the reply ailbee, ya i did update the graphics card and also the mouse,but still the same?
if i set hw buffer to 32 the noise frequency is high as i increase the hw buffer the noise gets lower? |
Re: Custom pc build
I have on board audio issues but I assume it was related to my Hackintosh Build
It doesn't bother me because I use my focus right Sapphire to do all of my PT audio But my on board audio off of the motherboard will also have static on it and it changes Pitch slightly with the buffer as well Like I said probably related to my hacking Tosh build but it doesn't cause any problems because I'm running my sapphire as my main audio channel
Re: Custom pc build
thanks for the replys guys, im still having this problem? i have onboard audio disabled in bios, im running two krk vxt6 from the omni and i cann still here the noise through the krks? its like every task the pc does comes through the krks.
im really lost on this one. is my sandra report ok? |
#16
Re: Custom pc build
anybody!!
#17
Re: Custom pc build
I would take this which is a dpc latency checker and run it with various tasks and see if anything is spiking it or if its staying at high levels.
i would shut off everything in the bios i could. lan ports, firewire ports, anything except necessities. other things in the bios to look at in the bios: Intel(R) Turbo Boost Tech. [Enabled] <= Standard (i think is the available choice...check this one tho)*** CPU Cores Enabled (Note) [All] CPU Multi-Threading (Note) [Enabled] (this is hyperthreading) CPU Enhanced Halt (C1E) (Note) [Enabled] <= DISABLE C3/C6/C7 State Support (Note) [Disabled] CPU Thermal Monitor 2(TM2) (Note) [Enabled] CPU EIST Function (Note) [Enabled] <= DISABLE Virtualization Technology (Note) [Enabled] <= DISABLE Bi-Directional PROCHOT (Note) [Enabled] *** if you are overclockin' TURBO mode should NOT be enabled This is copied from the i7 thread. This is Gigabyte nomenclature, so it will be a bit different for Asus. i would look at the ones in red and switch them back and forth and see if that helps. there was a similar issue on the original i7's that could cause a whine through the monitors that could be resolved in here. I would go those routes, vid card as albee stated, bios, and then psu. i would be prepared to swap it out and the vid card out with replacements of it dont get resolved.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 Last edited by guitardom; 05-18-2013 at 01:42 PM. |
#18
Re: Custom pc build
hey guitardom
i will check out all your sugestions thanks very much, hope i can sort this out asap.. |
#19
Re: Custom pc build
no prob and keep us informed.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#20
Re: Custom pc build
UPDATE.. For the past two weeks iv being trying to sort this problem out,but still same noise?
i had a pc tech come to my studio to look at my pc and he thought it was a fault with the onboard sound,so i got a replacement new motherboard sent to me but same problem exists! iv done all the normal bios settings, swaped out the graphics card. the only thing left to do is to try another power suply,im trying to source one at the moment to try out. is there anyone here using my exact pc parts with any luck? Asus rampage iv extreame -motherboard corsair h70- cooling corsair ax860i -power suply corsair dominator platinum 32 gb 1600- ram intel i7 3970 3.5 ghz- cpu nvidia quadro 2000- graphics card help!!! |
Custom PC Build - Pro Tools issues | hedcase23 | Pro Tools 10 | 16 | 02-27-2013 11:49 AM |
Windows 7 Custom Build Compatibility | lbarham | Windows | 8 | 08-18-2012 07:00 PM |
Custom build CPU wont read ANYTHING MIDI | RichieRocks | MIDI | 1 | 03-21-2011 08:38 PM |
New custom build for Pro Tools 9-Help needed | viperbri | Windows | 3 | 03-08-2011 04:15 PM |
Review of my Pro Tools Computer Custom Build | VicSandersMusic | Pro Tools M-Powered (Win) | 2 | 06-21-2009 06:08 AM |
