Old 05-10-2019, 03:44 AM
Akiz Akiz is offline
Default Artist Mix EuCon 19.5
I noticed a very strange behaviour after updating to the latest Eucon 19.5 and firmware v.1.5.6.0, in my Artist Mix surface. (Updated PT to 2019.5 as well.)
There is a very annoying delay in Page buttons when:a) Want to roll trough different page settings of an insert processor.
or b) when i try to add a plugin in an Insert from the surface.
I shot a video with my phone of that behaviour. In short, Page buttons do not work as they used to...
https://www.dropbox.com/s/yyi0hxvy8h..._0872.MOV?dl=0
As it is now, it's unusable for me. Can someone please check out, if it has the same issue?
Should i go back to previous Eucon version, or is the firmware an issue now?
Thanks for any insight on this...
Cheers!
Mac Pro 6.1 "Late 2013", 12 Core 2.7 Ghz, 32Gb Ram, 1Tb SSD, MacOs 10.14.6 "Mojave", Apogee Ensemble Thunderbolt, Softube Console 1,
Avid Artist Mix, Pro Tools Ultimate 2021.7.
Old 05-10-2019, 05:01 AM
Jamie Mac Jamie Mac is offline
Default Re: Artist Mix EuCon 19.5
I experience the same buggy behaviour on the S3
Old 05-10-2019, 05:12 AM
Default Re: Artist Mix EuCon 19.5 issue.
Hi Jamie,
Thanks for your reply! My findings so far.
Spend the whole morning troubleshooting this issue, did all the usual steps.
Uninstalled Eucon 19.5, deleting user settings too. Reboot my MacPro.
Installed Eucon 18.3, reboot... It works as expected, but i got a message that latest PT control will not work with this version. I can't go back on my iPad to previous PT control now...So, uninstalled Eucon 18.3 and installed again, 19.5, reboot. I used Preference Manager to backup PT preferences and after that i trashed them using the app. Reboot, same problem with my Artist Mix surface...
Conclusion: Eucon 19.5 breaks Artist Mix (i suppose Dock) and S3 functionality.
Will wait for Ed to check it out and let us know what to do next.
Cheers!
Old 05-10-2019, 05:19 AM
Sardi Sardi is offline
I don’t have your first issue. If I page through the plug in parameters, it works like it did before. No lag that I can notice.
As to your second issue, I can’t comment as I haven’t tried it. TBH, I never instantiate plugins from the control surface.
This update is working really well for me thus far. I’m literally doing backflips at the fact that I can FINALLY click on a plugin and have the control surface automatically spill the parameters onto the knobs. Can’t believe it took them this long to implement this seeing as it was a function on older control surfaces.
Old 05-10-2019, 07:08 PM
KingTor KingTor is offline
Don't let the clients see that our they'll come to expect gymnastic mixing.
sent from a stupid phone using Tapatalk
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 05-10-2019, 07:42 PM
Ha!
I wish I could actually do any form of gymnastics. Two collapsed discs in the lower back means the only backflips will be throwing my Artist Mix in the air and having it land flat on the desk. =P
Old 05-11-2019, 12:18 AM
That'd be pretty good. My son and his friends do that with just about anything. The big one is to "cap" a water bottle behind your back.
Old 05-11-2019, 03:55 AM
pavoni pavoni is offline
I have something that looks similar since updating. When paging through the insert parameters - the OLED screen doesn't always update correctly (some of the old labels get left on the screen). The on led does update correctly - and the rotary controls change the right parameter of the plugin - so looks like a bug in updating the display - not in doing the paging. I did update the firmware of my Mix to the new version.
Paging backward and workward will cause it to refresh - although not always correctly. Looks like the left labels are usually correct - but gets less reliable as they move to the right.
Old 05-11-2019, 04:06 AM
I've also now seen a situation where the page buttons stopped working - and changing between pans/aux inserts only partly update the OLED display. So pretty sure there is some sort of bug.
Rebooting the Artist Mix sorted it (at least for now)
Old 05-11-2019, 05:32 AM
Thanks for confirming that you have the same or similar issue.
There is definitely something wrong with this update and it is not a small issue IMO.
I like to use the surface for loading plugins on inserts or assign sends, it comes very handy to me, i'm used to it, since the days of D-Command...old habits die last....Anyway, hope someone looks after the issue and comes with a solution soon..
Cheers!
Can I change Eucon Layouts with an Artist Mix or Artist Transport? amathie Artist Series 10 09-21-2017 07:29 PM
Eucon sees my Artist Mix as an MC Mix TheDavidLim Artist Series 1 11-29-2016 09:42 PM
Artist Mix/Eucon Problem digitalpapaya Artist Series 0 04-19-2016 12:44 AM
Artist Mix with Eucon 3 very sluggish mrtomcat Artist Series 0 10-02-2013 11:43 PM
Artist Mix freezed , Eucon 2.62 peterle Artist Series 4 09-11-2012 08:32 AM
