Re: MIDI Play Lists
Much needed!
Pleeeeeeease Avid?
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1 |
Re: MIDI Play Lists
Agreed - also to sort the clip bin by track type would be helpful also....
Re: MIDI Play Lists
I comp Instrument tracks often.
Let's say you do a loop record 5 times, and have PT set to create a new playlist each go around. Just create (duplicate) 5 new tracks and set each to each of the 5 takes. Use the original track as the master take and put it on top. (Same as the playlist view). Play each take and find the gems. Separate the clip and highlight it by changing its color (I like yellow). Or use colors to grade them. Don't worry about the exact edges yet. Then slide up the good clips to the top track. (Use ctrl-shift when moving to keep them from changing position in the time line as you slide them up). Then edit the comp track to smooth all the transitions and make it sound like one take. If the instrument is big and you don't want 5 instances of it running, then create MIDI comp tracks instead of Instrument tracks. Send the output of the comp tracks to the VI on the master track before you start comping.
DC-Choppah's Project Studio: ASUS PRIME Z390-A / Intel i7 rackmount PC Windows 10 home 64 bit Pro-Tools 11.3.1 AIR Instrument Expansion Pack v2 WAVES Platinum plugin bundle Tascam US-16x08 Interface 100% Analog real time monitoring 16x4 Yamaha 16 channel MG16XU Analog Monitor Mixer Yamaha MX-88 / Novation XiO keyboards Mackie 4-channel headphone amp Adam A8X monitors Blue / Shure, etc. microphones Estonia 6' 8" Parlor Grand Piano Yamaha Studio Drum kit https://www.dc-choppah.com/ |
Shuffle editing and underlying play lists | wwittman | Pro Tools TDM Systems (Mac) | 15 | 12-20-2022 04:51 AM |
Field recorder channel and play lists | grant howarth | Pro Tools 10 | 6 | 01-03-2012 06:43 AM |
play lists in PT 8... bah | JonnyGinese | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 09-16-2009 12:05 PM |
"Delete Unused Play Lists" ??? | 25ghosts | Pro Tools TDM Systems (Mac) | 13 | 06-19-2007 03:28 PM |
Question about play lists | millicent frndly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-14-2005 10:26 AM |
