Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 01-12-2021, 01:36 PM
2crows 2crows is offline
Default monitors lo volume /attenuated?
howdy,
i have Carbon up and running , can record ,headphones are spot on but , my monitors, Presonus scepters S8, low volume , can barely hear them, i have checked everything i know to do , any suggestions welcome,
Thx
Old 01-12-2021, 04:42 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Re: monitors lo volume /attenuated?
Originally Posted by 2crows View Post
howdy,
Thx
- What is the level set to on the back of the Presonus speakers?
- You're using MON L-R on Carbon, right?
- In Pro Tools > Hardware Setup > Line I/O, is +4 or -10 selected for MON L-R?
- What's the green LED strip level (i.e 60%) on front panel of Carbon when Speaker button is enabled (also green)? If you can send a picture of the front panel, that'd be helpful.
Thanks.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 01-13-2021, 09:31 AM
Got it Kyle , user error, monitor button is now greeN , embarrassing
Old 01-13-2021, 10:06 AM
Ok, glad to hear that. FYI, here's a video of configuring speaker sets which may be useful: https://www.youtube.com/watch?v=ORlU...YekJAY&index=8
Kyle Splittgerber
Berkeley, CA
Old 01-13-2021, 12:45 PM
nst7 nst7 is offline
While we're on the subject of monitors for Carbon, I wanted to ask something. Can the main monitor outs 1-2 be changed to a regular line out that's not attenuated? For example, if I was doing surround work with a separate hardware monitoring device and wanted to use 1-2 in addition to the 8 line outs, for a total of 10 line outputs, which would then be attenuated as needed from the hardware monitoring device.
Old 01-13-2021, 01:58 PM
Yes, that's straightforward. You simply uncheck any active monitor sets (Main, Alt 1, Alt 2) in Pro Tools > Hardware Setup.
Kyle Splittgerber
Berkeley, CA
Old 01-16-2021, 10:29 PM
Is there any chance that avid will get up with Dave Smith instruments , a great , proprietary to PT synth plug in
How To Adjust Volume of Studio Monitors in PT12? johnbarnesiii Pro Tools 12 5 07-19-2016 03:11 PM
Low headphone volume when using studio monitors Deshi88 Eleven Rack 1 06-04-2016 06:32 PM
What volume should I set my monitors? iannetta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-02-2010 08:23 PM
Powered monitors and volume control kastadyne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 09-17-2004 08:11 PM
Volume Pot From Adat Bridge to Monitors??? Kitch Pro Tools TDM Systems (Mac) 6 01-01-2003 09:13 AM
