Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 03-31-2018, 08:11 PM
Mahkyb Mahkyb is offline
Default Registry Error
HI,
I downloaded PT First and when I launch it gets caught up
scanning plugins and it gives me the registry error pop up message.
As a result, PT will not open.
I'm assuming it has something to do with the Space plugin but
how do I update it so that it doesn't happen?
Thank you in advance for your help.
Old 04-02-2018, 04:57 PM
Default Re: Registry Error
BTW, I have the following:
Macbook late 2008
El Capitan 10.11.6
8 gb ram
500bg SSD
Any ideas about the registry error?
Old 04-03-2018, 05:50 PM
Default Re: Registry Error....Update
So, I've updated Space and everything else in the App Manager but when I try to launch PT's First it's still asking for an activation for Space.
What else do I need to do?
Old 04-05-2018, 04:31 PM
jeffro's Avatar
jeffro jeffro is offline
Pro Tools First supports "plug-ins purchased from within the in-app Store" (see avid.force.com/pkb/articles/faq/Can-I-use-any-AAX-plug-ins-with-Pro-Tools-First). Where did you purchase Space from?
Old 04-05-2018, 05:06 PM
Hi Jeffro,
Thank you for responding!
I honestly don't remember purchasing it. However, why would it be in my App Manager if it's not available to me? Also, if I didn't buy it then why would it be causing a registry error so that I can't launch PT's First?
Old 04-05-2018, 05:18 PM
jeffro's Avatar
I see a monthly Pro Tools Subscription in your account that ended recently. Likely a left over from that (the Pro Tools Plan license authorizes Space). You can let PT move it to Plug-Ins (Unused) on launch or manually delete it from the Plug-Ins folder.
Old 04-05-2018, 06:40 PM
So, I went in and deleted the Space plugin. When I launch PT First it's not giving me the message about Space anymore but I'm still getting the
registry error. It has to be another plugin because it keeps getting stuck at
the scanning plugins portion during launch.
Old 04-05-2018, 07:03 PM
Okay, so I took all my plugins and moved them into the plugins unused file. I launched PT's and it opened!!!!!
Now, I have to put them back one by one to see which one is causing the issue. This may take forever.....
Old 04-05-2018, 08:40 PM
jeffro's Avatar
Progress!
It's usually quicker when searching for the culprit in a large group to split the failing group in half (and keep repeating that).
Old 04-06-2018, 06:00 PM
Yes! Finally figured out that some of my purchased plugs like Amplitube need to be update to 64 bit. That's why I was getting the registry error. Thanks for sticking with me on this Jeffro....
Registry Error on Mountain Lion 2hip2b4real Pro Tools Software (Mac) 7 12-24-2012 11:11 PM
Pro tools 10 registry error FifthNation Pro Tools Software (Mac) 0 11-23-2011 12:38 PM
The Comprehensive Buffer Error Registry vibrolux40w 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-15-2007 01:51 PM
VST to RTAS registry error HELP Joz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-20-2004 07:24 AM
Registry error stevensu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-01-2000 04:30 AM
