Old 01-25-2016, 03:29 PM
yonkiman yonkiman is offline
Default Elastic Audio "Remove Warp Marker" doesn't remove the warp marker
I'm in warp view, algorithm is set to monophonic, and I want to remove multiple warp makers. I select the range containing the warp markers I want to remove, right click, and choose "Remove Warp Marker". The warp markers are NOT removed and my selection collapses to the left side of where the selection was. I also haven't been able to remove a single warp marker. However I can easily warp the entire clip...
What am I doing wrong?
I'm using 12.4.0 on Windows 10 if that matters.
Old 01-25-2016, 05:16 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Re: Elastic Audio "Remove Warp Marker" doesn't remove the warp marker
As far as I know Windows 10 isn't supported, so maybe that's one of the issues.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2018.10, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 01-26-2016, 03:14 PM
That may be it. Meanwhile, try double-clicking on any single marker to see if it goes away
HP z820 12 core, 64GB RAM, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs, Warm Audio and Midas..............................
Old 10-25-2018, 07:52 PM
kirkbross kirkbross is offline
The blue triangle goes away if you double click (or Option + click) but the little gray marker line stays and if you try to drag an adjacent marker past the one you don't want, you're out of luck.
If you hit Option + 5 (number pad) the elastic audio properties comes up and then select the audio region or clip and you can lower the sensitivity which will remove marker points according to transient algorithms.
I usually lower it a tiny bit to about 96% and then manually add back markers as I need them with Ctrl + click.
Pearlman Church Microphone > Great River MP-2NV > Warm Audio WA-76 > Apogee Symphony 8x8+8MP > PT12 on 2008 Mac Pro with 16GB of RAM running High Sierra on a 500GB SSD.
warp marker doesn't show up! stargazerbass Pro Tools 11 28 10-04-2015 09:54 AM
Does ELASTIC AUDIO always leave artifacts on every warp marker P,B,S Pro Tools 10 5 01-23-2013 12:15 PM
"remove warp" spiritkid Pro Tools M-Powered (Mac) 2 03-13-2010 04:45 PM
Warp Marker Problem shultzee13 Pro Tools M-Powered (Mac) 0 02-07-2010 10:27 AM
unable to move warp marker Bart HLH Pro Tools TDM Systems (Mac) 3 10-09-2008 09:11 AM
