pro tools could not initialize the focusrite usb asio
Pro Tools 12.5.x
Focusrite Scarlett 18i8 Gen2 Latest Focusrite Control and Drivers Win7 I've been running smooth but I'm now getting this error "pro tools could not initialize the focusrite usb asio" The Session opens fine But the error pops up when I hit play It seems to happen on 48k Sessions But at times it will pop up on any sample rate session A restert is needed after every time I get the error Thanks for your time and Help |
Re: pro tools could not initialize the focusrite usb asio
Do the latest Focusrite drivers support Windows 7? Ah you can't tell either.... how is anybody supposed to work out OS with is compatible with what?
What exact device are you using as the playback engine... is that the ASIO Focusrite device? Make sure you do not have ASIO4ALL installed/are accidentally trying to use that. Is Windows sound or other apps trying to use the Focusrite device?... you need to set them to use a different device. |
I went through all the settings with Focusrite Support
He Knew I was on Win 7 and didn't mention compatibility issues? No ASIO4ALL Installed I've ran Other Audio and Video apps with no issues It still seems to come down to the few 48k sessions I open then everything is haywire! Thanks for your input Darryl |
Really double check that Windows sound and no other apps are trying to use that interface, that is very likely to be the cause here. Did Focusrite support work through that with you?
Lots of posts on DUC about that and related problems, e.g. http://duc.avid.com/showthread.php?t=389551 |
Hi Darryl
Thanks again for your feedback!!!! In the Sound control Panel Playback devices and the Record Devices the 18i8 is disabled The Speaker Icon on the tool Bar has an "X" In it I checked the Link you sent and the original poster to the thread never said if his problem got fixed? Strange how it is Just the 48k Sessions??? |
Avid ASIO won't initialize my hardware | sean shannon | Pro Tools 10 | 5 | 02-24-2016 02:43 PM |
Pro Tools could not initialize the Yeti Pro ASIO error | pvtrainer | Pro Tools | Intro Discussion | 1 | 11-12-2015 09:40 AM |
Pro Tools could not initialize the Yamaha Steinberg USB ASIO..... | CraigMusic | Pro Tools 11 | 2 | 07-14-2015 03:22 PM |
Windows 7 x64 PT10.2 Could not initialize ASIO ESI MAYA 44e | peterpan | Windows | 1 | 08-07-2012 09:22 PM |
Pro Tools 9 wont initialize ASIO driver for Realtek HD audio device and more | fireal2112 | Windows | 19 | 05-05-2011 11:16 PM |
