Old 02-03-2017, 11:13 AM
mfruet mfruet is offline
Default DIGI 003 Rack- PT HD 12.7 miss up Analog/Adat I/O
I have Pro Tools HD 12.7 running in a Mavericks Mac Pro with a DIGI 003 Rack. I'm running the latest 003 driver.
What happens is:
- In the I/O menu the interface inputs and outputs are divided wrong. It shows as analog section was from channel 1 to 9 (but the 003 goes u to 8 channels only) and Adat session starts in channel 10, which is also wrong. This is confusing things here and somehow my last analog inputs stopped working (at least it's what it seems) but sound like a routing error because of that.
- See pics to easily understand, please.
Any help?
Thanks!
Marcelo
Old 02-03-2017, 12:05 PM
Default Re: DIGI 003 Rack- PT HD 12.7 miss up Analog/Adat I/O
I don't think Maverick and PT12.7 are compatible.
Old 02-03-2017, 06:52 PM
jeam25's Avatar
jeam25 jeam25 is offline
Hi Like albee ^ said . But have you tried to manually reassing them ?
- Jesus Alvarado -
Keep the volume UP !
Old 02-03-2017, 09:26 PM
gonsdeejay's Avatar
gonsdeejay gonsdeejay is offline
Jeam, Remember, When you Open a Session at 96khz, or 88.2Khz; 003R will not show ADAT, ADAT, Only works at 44.1 and 48Khz....
Pro Tools 2018.12. UAudio Apollo 8 Duo & Apollo Twin. Custom PC i7-7700K 16 Gb Ram Thunderbolt 3 SYSTEM-1KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Mackie MCU Producing My Own Life
Old 02-03-2017, 09:33 PM
JFreak's Avatar
JFreak JFreak is offline
settings itself are correct, but the header is wrong. some coder needs to smash this bug
Janne
Old 02-03-2017, 11:00 PM
nate9's Avatar
nate9 nate9 is offline
I haven't used PT 12.7 yet, is there a control for the clock setting? If your using Adat make sure it's set to Adat. Also, make sure your input's and output's on the analog track's that aren't working are set to the proper input and output.
Thank you,
Nathan
Control24, Digi 002, Rosetta 800, KRK V8's, PT 7.4
Macintosh G5 Dual 2.0 3 gbs ram
Old 02-04-2017, 08:59 AM
And one more thing that might be worth trying; make all the input paths MONO and see if that allows analog #8 to function
Old 02-04-2017, 10:41 AM
Yes it is according to avid:
http://avid.force.com/pkb/articles/d...7-Release-Info
Old 02-04-2017, 10:43 AM
Yes I did, but it doesn't change the way it is organised...
Old 02-04-2017, 10:44 AM
Originally Posted by nate9 View Post
Thank you,
Nathan
This is fine already. Thanks.
Digi 003 rack, how many analog inputs can I use at once? sneakyimp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-28-2014 04:42 PM
Digi002 Rack - send analog inputs through ADAT out? copperpipe General Discussion 2 06-05-2007 04:57 PM
Does anyone miss analog mixers? DougSt.Louis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 08-08-2002 02:34 PM
8 analog INS to ADAT interface for DIGI 001 cyril 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-01-2001 09:13 AM
Adat I/O on the Digi 001 : Alesis AI3 for extra analog inputs PGrealy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-08-2001 06:03 AM
