PT HD to DA-88 TDIF xfer problem
Doing a digital xfer from PT HD 192 I/O via TDIF to a DA-88 yields full scale digital noise. Answerbase specifies this is a known problem that gets fixed by 5.3r4 update (not yet available?). Any work-arounds or experience using a DA-98, which digi says this problem doesn't exist with.
Thanks. |
Re: PT HD to DA-88 TDIF xfer problem
In my case, everything is clocked through an external video black reference generator, and it's working fine. At the worst, I would try using a break-out cable going to AES/EBU and see if that solves the problem. --Marc W. |
The other option is to get an IF-88AE, and to the AES/EBU thang. But my way does work perfectly. Craig |
That explains the problem that I had not too long ago. Trying to get dig into DA88 from PT yielded full on level a the DA88 with no signal being sent from PT. Brought in a DA98 and it worked fine using the very same cables. Thinking that my DA88 was wacky, I brought it into be repaired, only to find that there was nothing wrong with it.
I'll give the terminator a go and see if it behaves. Thanks. |
Xfer Nerve 1.1.2 - Now AAX! | steve_xer | AAX Plug-ins | 11 | 03-19-2014 12:15 PM |
DA88 TDIF Out to 192 TDIF IN | Mixing Madness | Pro Tools TDM Systems (Mac) | 2 | 11-07-2011 09:31 PM |
Xfer & Pull Down | estephano67 | Post - Surround - Video | 1 | 01-07-2004 09:24 AM |
Xfer TDM to 001 | Seegs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-14-2000 08:48 AM |
Digital Xfer | Precava | Tips & Tricks | 2 | 10-28-1999 10:15 PM |
