Old 01-20-2006, 05:14 PM
jtbullitt jtbullitt is offline
Default Assign automation to a fader or knob on Digi002?
My apologies if this is basic/obvious/already been answered a million times, but I can't seem to find it mentioned anywhere in the Digi docs, this conference, or in my ProTools books...
Can anyone tell me how to assign an automation control to a real-world physical knob or fader on the Digi-002? I'd like to record a couple of automation parameters simultaneously by tweaking a couple of sliders or knobs at once, rather than just by shoving the mouse pointer around on the screen.
Any ideas?
Many thanks.
- John
Old 01-20-2006, 05:34 PM
da critic da critic is offline
Default Re: Assign automation to a fader or knob on Digi002?
this is not ant accuall reply to this message i have a question. i,m trying to assign automation of a plug in to a curtain section of a vocal and its putting the plug in on the whole vocal and not just that section can anyone help me!!!!!!
Old 01-20-2006, 05:45 PM
jtbullitt and da critic
Automation
Pro Tools Tips and Techniques Plug-in Automation
filosofem
Aaron Mulqueen - 001 HD Native
Old 01-20-2006, 06:09 PM
Thanks, filosofem, for the reply. Alas, those references don't quite address my original problem.
In all the automation examples I've seen (like the one in that nifty DiskFlix demo that you mentioned), the plug-in automation parameters are "performed" by pushing the mouse around. Is there a way instead to "perform" the automation by twirling a knob on the Digi002 hardware?
Thanks!
- John
Old 01-20-2006, 06:26 PM
jtbullitt
Quite right you are, but have a look at the section "Automation Accurancy with Control Surfaces". This may not be an option for you. Sorry I should've read your post a little more carefully. I don't own a Control Surface so I wouldn't be able to help and someone with a Control Surface will be able to confirm this, but have you tried holding down Ctrl+Windows+Alt and moving a fader?
filosofem
Old 01-20-2006, 06:57 PM
Thanks, filosofem, for the hints, which led me to the answer to my original question:
It appears that the Digi-002 does not support automatable faders or knobs. The rotary encoders on the Command|8 control surface are, however, automatable. So, with a Digi-002 the only way to "perform" plug-in automation is by mouse. Oh well.
Of course, if anyone can convince me otherwise, I'm listening!
- John
Old 01-20-2006, 09:35 PM
YttriumMusic YttriumMusic is offline
???? I record automation all the time from my Digi 002 ??? What, exactly, are you trying to automate? If these are plug-in parameters, does the plug-in support control surfaces?
I have done track volume, panning, muting, and a few plug-in parameters on my 002 without any problem. I just use the control surface instead of the mouse. (I've even done both--switching between the keyboard and the control surface)
Why have a control surface if it doesn't support automation?
Out of curiousity, are you able to record ANY automation on your 002? For example, if you enable track volume or panning, does that automation get recorded from the 002?
Old 01-21-2006, 01:43 PM
For example: The center frequency of a notch filter in the Waves Q10 Parametric Equalizer (a plugin in one of the Waves bundles). How do I set things up so that by turning a knob on the 002 I can control the center frequency of that filter?
I'm assuming that Waves plugins support control surfaces.
Oh, yes. I do that all the time. The basic (non-plug-in) functions like pan and volume work just fine. I just can't figure out how to get the 002's faders and rotary encoders to control RTAS plugin parameters.
You said that you've automated "a few plug-in parameters on my 002". I'd love to know how you did that.
Thanks.
Old 01-21-2006, 05:23 PM
OK, I don't have any Waves plug-ins, so I can't tell you how to do exactly what you want. But this works for me.
1) Set the track to record automation (Generally, set at "write" if there is nothing there before)
2) Set the automation window to record automation for plug-ins. (I generally make sure it gets ONLY what I want so I don't accidentally automate volume or something else I didn't intend)
3) On the Digi002, select the "Insert" button and select the plug-in that you want to automate.
4) Using the "Page" button, find the page with the parameter you want. The scribble strips will have (poor) 4 character abbreviations of each parameter. I think there is a way to get focus to follow the control surface, but it's been a while since I've done this.
5) You can use the rotary encoder immediately below the parameter that you want to automate *OR* you can use the flip button to send it to the faders for more precise control.
That's it. I don't remember ever doing anything extra to make it work. Are you able to access the plug-in parameters from the 002? If so, I'd imagine that you can automate it at that point, especially if your mouse movements work in automation.
Old 01-24-2006, 07:03 AM
1)....
Ah, brilliant! Your step-by-steps worked like a charm. Now I can tweak all my plugins to my heart's content using the faders. You've opened the door for me to a whole new world in the 002.
Many, many thanks.
- John
P.S. I guess now I should finally read the manual to see what other important features I've been missing. ("Oh, you mean that little rocker switch in the back turns the 002 on? I always wondered what that thing did.")
Assign "mod wheel" to another knob on keyboard? tobbenos MIDI 3 12-07-2010 10:45 AM
Fader Direct Assign jacko Artist Series 1 11-06-2010 04:55 PM
ow do I assign groups to a fader in LE 7.4.2 dbluprecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-06-2009 12:07 PM
User Assign Matrix Ch sent Post-Fader? Ryan H VENUE Live Sound Systems 9 11-19-2009 01:16 PM
DIGI002 fader automation AFU!!! H.M.F.I.C. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 03-05-2003 01:37 PM
