  #21
Old 01-07-2012, 01:36 PM
TheVRsNo$ TheVRsNo$ is offline
Default Re: Unsupported audio buffer size in device control panel
Originally Posted by hue View Post
Well It wouldn't be unusual to think he failed. It is GC after all. Most of them are just as newb as some of the people here.
Yeah like myself, haha. But I was actually talking to him and he does music as well using Ableton and Logic. Seemed as if he knew what he was talking about. I may be a newb, but I'm pretty damn good at reading people.
  #22
Old 01-07-2012, 01:44 PM
Now the error message is:
"The selected ASIO audio device could not be initialized. Please choose another audio device."
  #23
Old 01-07-2012, 02:08 PM
Just downloaded ASIO4all and now I have created a project and assume I can start diggin into the program to figure out how to use it! Appreciate everything gentlemen!
I make hip-hop, mainly recording vocals and mixing them. Any advice as far as settings and other things please email me @ [email protected]
Thanks again guys!
  #24
Old 01-08-2012, 04:10 PM
xzb6np xzb6np is offline
The us800 is not compatible with pt9 in windows. I bought one, had the same issue, called tascam techsupport and that is what they said. They also said they do not plan on fixing it. I sold it and got a Presonus 44vsl. Works great!
  #25
Old 05-24-2012, 11:31 PM
maxspl maxspl is offline
The Tascam US-800 does work with P9 in Windows- somewhat.
I am running Windows 7 and PT 9 on a Toshiba machine. I had to use the ASIO4ALL driver. I had to play with the buffer size in the US800 driver window. I think 512 and higher work. And, yes, the other "little" glitch is that PT9 only sees the first two inputs.
The US-800 comes with Cubase LE5. That works with all channels. So, you could use that to record and PT9 to mix. It also works with Audacity 1.26 in Windows XP. Audacity is free. Unfortunately, that version does not work with Windows 7. The latest version of Audacity, 1.36, does not support more than two channels of recording.
English!? Who needs that? I'm never going to England!
Homer Simpson
  #26
Old 12-11-2015, 08:01 PM
jbo725 jbo725 is offline
I'm having the same problem this guy was having. I did what you guys said to do which is hitting the "n" key while opening pro tools I have 12 by the way, but the buffer size menu won't even open up. I can select everything else except any of the buffer sizes. Why is that if anyone knows can you please help me out with this.
  #27
Old 12-12-2015, 10:28 AM
The Weed's Avatar
The Weed The Weed is offline
Try setting your onboard soundcard as the default for Windows sounds/audio and leave your interface for Pro Tools only.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
  #28
Old 12-09-2019, 06:28 AM
Kinh Kinh is offline
None of the above solutions work. Anyone know how to fix this?
I'm all of a sudden locked out of protools for no reason whatsoever! I made no changes to protools, it's soundcard settings and I get this rubbish.
Totally unfair.
Intel 6 Core i7-4930K CPU @ 3.40GHz
32GB DIMM DDR3 G.Skill
Samsung SSD 840 EVO
WD Black SATA 7200
ASUS SABERTOOTH X79
Windows 7 Ultimate 64
Mbox3 Pro Firewire 400
ProTools 10.3.8
ProTools 11.3.1
https://soundcloud.com/matthewcrowe
FYI: PT 10.3.3 complains about unsupported buffer size 2048 Niilo Nuori Windows 0 02-22-2013 03:43 PM
Control Panel and Pro Tools show different buffer size (latency). birdfluvirus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-10-2012 09:11 PM
Error at startup: "Your audio device is configured with an unsupported buffer..." Kronos78 Windows 0 05-03-2011 01:39 PM
ProTools won't launch; unsupported buffer size DarylG Windows 3 02-23-2011 08:07 AM
Wavedriver - sound control panel: No Audio Device misterkay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-07-2004 05:47 PM
