Old 04-07-2004, 07:07 AM
misterkay misterkay is offline
Default Wavedriver - sound control panel: No Audio Device
Okay, I know this has been covered, but after starting from scratch I simply can't get my PC to "see" the 002 (rack) to send audio out of. This is in Control Panels -> Sounds and Audio Devices. However, the midi ports to the 002 show up in the Audio Tab under Midi Playback devices. And of course I can run Pro Tools without a hitch, so there is no problem there. I have Windows XP up-to-date, AMD Athlon XP 2800, 1 GB RAM. Previously I was using the Nvidia Nforce Card for audio other than pro tools. I have uninstalled that driver thinking that was the problem. But now I am at complete loss. If anyone has any ideas, they'd be greatly appreciated.
2 X 3GHZ Dual Core Intel Xeon
6GB Ram
OSX 10.5.5
Pro Tools LE 8
Old 04-07-2004, 08:40 AM
Default Re: Wavedriver - sound control panel: No Audio Device
okay, I have continued to research this on this forum, and have tried uninstalling, re-installing, and I can tell that the MMEhelper works, but there is still NO audio devices found in the sound control panel. I will continue to use Nuendo with some other interface if I can't solve this, but would really like to try the 002 - but not if it prohibits me from hearing any other audio except out of Pro Tools. Is there anything else I should be doing besides starting at 6.1 and then updating again?
6GB Ram
OSX 10.5.5
Pro Tools LE 8
Old 04-07-2004, 09:33 AM
Bazzle Bazzle is offline
Did you try reinstalling the Wavedriver.There is a protocol that Digi suggests somewhere on there download site. I think it goes like this.Install 6.1_install 6.1.1_install Wavedriver_install ASIO.
Bazzle
Old 04-07-2004, 02:07 PM
I will try that protocol - thanks!
6GB Ram
OSX 10.5.5
Pro Tools LE 8
Old 04-07-2004, 02:34 PM
Which 3rd party apps are you trying to use?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-07-2004, 04:14 PM
I have been running Nuendo with an M-Audio Firewire 410. But since I have a bunch of work coming up that I'll be going back and forth with Pro Tools, I'd like to switch to the 002 for both Nuendo and Pro Tools. The motherboard I have (the PC was built by a friend) has an Nvidia Nforce Audio/Video card...this is what the Sound control panel defaults to using for Audio out. But when I disable those audio drivers, the 002 still doesn't show up. The other workaround is simple...go out the stero mini-plug into the Alternate source RCA inputs on the 002. I read through the past posts and there do seem to be a number of success stories...perhaps the issue has something to do with the Nvidia hardware rather than the wavedriver software?
6GB Ram
OSX 10.5.5
Pro Tools LE 8
Old 04-07-2004, 05:47 PM
With Nuendo, you should use the ASIO driver.. but you can't use the Digi hardware with more than one app trying to use the I/O at the same time.
Rail
Platinum Samples
Unsupported audio buffer size in device control panel TheVRsNo$ Windows 27 12-09-2019 06:28 AM
ASIO device properties have been changed by the device control panel. medinarawk Third Party Interfaces 5 07-06-2015 02:18 PM
Cant see dig001 as midi device in XP control panel ruben74 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-02-2003 11:11 PM
Sound Control Panel stefano manelfi Pro Tools TDM Systems (Mac) 0 09-28-2003 06:51 AM
sound control panel/audio input? anders Tips & Tricks 1 07-13-2000 09:28 PM
