Old 10-14-2006, 08:32 PM
Eric Maia Eric Maia is offline
Default kernel panic when quitting protools
I am having frequent problems with kernel panic (gray multilingual screen of death) when I quit protools. I recently had hardware problems fixed on my powerbook, and I erased the harddrive and re-installed everything. It has been since this that the kernel panic problem started. ProTools works OK otherwise, but the kernel panic thing is getting really old. Has anyone else had problems like this? Any suggestions?
Thanks
powerbook g4 1.67 GHz, 1.5 GB ram
OS x 10.4.6
ProTools LE 6.9.2
MBox
Old 10-14-2006, 09:21 PM
M.Brane M.Brane is offline
Default Re: kernel panic when quitting protools
Bad RAM?
Looks like a job for Memtest.
Old 10-15-2006, 09:08 AM
Thanks, I'll check it out. Will this catch problems that the apple hardware test won't?
I have already sent the powerbook back to Apple twice, and I think they replaced both motherboard and memory each time. I do not relish the prospect of going through that a third time.
Old 10-15-2006, 12:22 PM
Yes it will. It's the most thorough test there is short of a hardware RAM tester which are big $$$$.
Kernel Panic Bray90820 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-29-2010 11:14 AM
Mbox 2 Mini causes Kernel Panic after 8 months of no issues. Panic Report Included... oneakmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-09-2010 08:52 AM
Kernel Panic with 003 DSwartz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-04-2010 10:48 AM
Kernel Panic since PT8 LE TCLguy1 Pro Tools TDM Systems (Mac) 10 04-29-2009 09:02 AM
Kernel Panic in 7.4.2 dopewerewolf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-02-2009 07:48 AM
