Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 02-18-2020, 07:21 AM
richk522 richk522 is offline
Default Pro Tools First Install Issue
I'm new to Avid\Pro Tools, but I downloaded Pro Tools First and installed it on my Surface Pro 4. When I started the program, nothing happened. I tried uninstalling and re-install, and the same thing. Is it compatible with the Surface, or am I missing something?
Old 02-18-2020, 07:32 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Pro Tools First Install Issue
So I'm guessing when you say nothing happened that you didn't even get the splash screen; is this correct?
Do you see PT in Task Manager when you attempt to start it?
Can you try running PT as Administrator when you launch it?
Will K
System Details
Old 02-18-2020, 08:07 AM
Southsidemusic's Avatar
Have you registered at ilok.com and downloaded the ilok license manager and made sure you are connected to internet at all tiles as PTFirst need an internet connection to work and the steps I posted too.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 02-24-2020, 01:22 PM
rodno rodno is offline
In Windows I had to uninstall PTF 2019.6 then I installed PTF 2019.5 rebooted and then installed PTF 2019.6 rebooted and then it loaded just fine. Hope this helps.
Pro Tools 12.8 Install Issue tubby1kanobee Pro Tools 12 1 08-23-2017 11:45 AM
Pro Tools First Install Issue 08BlueSky Getting Started 2 02-10-2017 01:07 PM
Pro tools 10 install issue Ianchan03 Pro Tools 10 3 07-09-2013 09:14 PM
Pro Tools 10 install issue (HD Driver x64 missing) ? ionactive Pro Tools 10 2 01-04-2013 01:55 PM
Pro Tools 8 LE Re-Install Issue ibmarc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-04-2012 07:44 PM
