#31
Re: Pro Tools 12.1 and Application Manager
In that case, I wish I had your problems! I just fired up PT 12.1 and at 3 seconds into playback it made a LOUD stuttering noise and shut down, whilst continuing to stutter til I restarted Windows. Upon reboot, I started PT again and things seemed smooth until...I left PT running (not playing) while I got my guitar ready. I took about 10 minutes. When I sat back down PT was completely locked up!!!
Is there a method out there for starting from scratch? Should I go back to PT 12.0? Re-install the HD drivers as well? I just want to record!!!! So frustrating.
, Zuma M-box II Pro Windows 7 |
#32
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
#33
Thanks for the advice. I will do so.
#34
Re: Application Manager reporting update available that's already installed
I just wanted to give a quick update here and say that I was definitely having issues separate from the Application Manager bugs. It's possible my drive needed a firmware update and/or my Mbox 2 Pro simply doesn't play nice with 12. I went back to 11.3.1 and it seems pretty solid now.
I wrote a more lengthy update in the Pro Tools Software (Win) forum: http://duc.avid.com/showthread.php?t=369739
#35
Having the exact same issue. I was going to post the exact same screenshot that 'txrx' posted so I won't bother. I have 12.1 installed and working. Application Manager says I have 12.0.0.456 and need to update. Control Panel says I have both 12.0.0.456 AND 12.1.0.94. The version of Application Manager is 2.4.2.6435. I'm not going to touch anything yet, but I definitely want to remove the old version 12.0.0.456 of Pro Tools if it's really still there. I look in the Program Files folder and I don't see multiple copies, so it must just be a registry entry that needs to be removed. If I dare to f#%k with it, I'll post my results.
In the meantime, Avid, please advise on how to deal with this. thanks! ::UPDATE: Decided to look in regedit for the version of Pro Tools. Every entry I found mentioned 12.1.0.94. Nothing about 12.0.0.456. I really don't know where Application Manager or Control Panel is seeing the old version. Really need to figure this out. I'm in the middle of several projects and I need to trust this!!! Last edited by Multiguy; 07-26-2015 at 09:46 PM. Reason: update |
#36
updated app mgr
i just did the update for app mgr and it still says i have PT 12.0.0.456 which i don't!!! i have 12.1 installed and app mgr wants me to install an update for PT again. so i reckon it has not been fixed.
i have never taken pictures of people in the nude... i usually keep my clothes on KNOT HARDLY PRODUCTIONS LLP* Knot Hardly Esquire Farcebook Twatter _/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/ Window$10 FX4300 MSI970A-G46 16Gb AMD7870 _/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/ *a Limited Liability Persona |
#37
Re: updated app mgr
Thanks for the heads up. Won't be wasting my time with it.
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
#39
cool! thanks for the info Jeffro. so no worries then... that will probably be fixed in the next PT update for sure then. fingers crossed but that should be somewhat of a simple fix. cheers
jay
#40
Application Manager not working - Stuck on ver. 12.0.0.456
I'm running Application Manager version 2.4.2.6435. AM is reporting that there is a new Pro Tools Version 12.0.0.456 available. In fact I'm running PT 12.1. If I try to hit INSTALL button the installation fails. How do I revert to a working state of the AM so that I can make sure that I will get later PT updates? Thank you.
Rgds https://soundcloud.com/1iveowl/ Pro Tools 2018.4, Windows 10 Pro x64 (w/ latest update), i9-7980XE, ASUS TUF X299 Mark II, 64 GB Memory, Samsung 850 2TB SSD, UAD Apollo Twin II TB, RME Fireface USB, UAD-2 Octo PCI, Plugins: UAD Waves, Softube, FabFilter, Lexicon, NI Komplete 11 Ult, Celemony, Slate Digital, PSP, Arturia V Collection 6, FXPansion, iZotope, SoundToys, Spectrasonics... Last edited by jasperhb; 07-29-2015 at 04:39 AM. |
Can't Log In to Application Manager | Josh523 | Pro Tools 12 | 3 | 08-21-2016 08:44 AM |
Application Manager downloads | rankinfile | Pro Tools 12 | 11 | 01-01-2016 04:19 PM |
Application Manager | hooksound | Pro Tools 12 | 0 | 04-08-2015 10:00 AM |
new Application Manager suggestion | clausiii | Pro Tools 12 | 0 | 04-01-2015 01:29 AM |
