Old 03-26-2020, 05:48 PM
dmoffat dmoffat is offline
Default Lost Authorization PT10 on CrossGrade
hi folks
so just want to know if i pooched myself???
Bought a newer Laptop and installed Mojave on it and installed PT12 onto it.
My Imac had PT10.. loaded up with plugs etc.. and was going to use this still as my main unit ( didnt want to have to try an replace all the plugs $$$$)
I did a crossgrade to authorize my new Pt12... in doing so.. My Pt10 authorization is now gone...!!!
Do i have to get a new key for my Pt10???
Thanx for your help
david
Last edited by jeffro; 04-01-2020 at 10:28 AM. Reason: Moved from the "Getting Started" subforum.
Old 03-26-2020, 07:32 PM
Default Re: Lost Authorization PT10 on CrossGrade
Hi, welcome to the community.
What does your iLok License manager tell you about your license?
Old 03-26-2020, 07:34 PM
By the way, PT 12 is not supported on Mojave. Compatibility info here.
Old 03-27-2020, 03:50 AM
In addition to the above exactly what did you do to get PT12? Did you get a reinstatement plan perpetual license for $299? If so I believe that's the only one that has a combo license of PT 10/11/12/2019. If you did anything else you only get a license for PT 2019.
Old 04-01-2020, 08:32 AM
thanx for the reply.. My PT10 vers has completely disappeared to be replaced by "PT Subscription"
.. and yes.. i know 12 is supported on Mohave... but it also wasnt working at all in Catalina
thank you
Old 04-01-2020, 08:33 AM
HI Musicman
I used the "cross grade" function.
Old 04-01-2020, 08:39 AM
Originally Posted by dmoffat View Post
HI Musicman
That's why you don't have PT10 any more. Should have paid the $299 reinstatement and you would still have your PT10 license asset. PT12 is NOT supported on Mojave; the last supported OSX is High Sierra.
Old 04-01-2020, 10:28 AM
jeffro's Avatar
jeffro jeffro is offline
...I did a crossgrade to authorize my new Pt12... in doing so.. My Pt10 authorization is now gone...
Welcome to the community.
Can you please start a support case via the Support Center link in your my.avid.com account to get us the System ID and account info? Thanks!
linkedin
Old 04-07-2020, 02:56 PM
metalmixer metalmixer is offline
hi folks
Thanx for your help
david
Yes PT 12 will work on Mojave check this how to video out
https://www.youtube.com/watch?v=KKPG-0EJTDI&t=1s
Lost authorization code. PT10 registred on iLok2 mrdmn Licensing & Accounts 1 09-16-2016 09:58 AM
Upgrade to PT12 if i have lost the Ilok with my PT10 authorization Joeyvanimpe Pro Tools 12 2 08-11-2015 09:53 AM
PT10 crossgrade authorization problems martthie_08 Pro Tools 10 2 02-27-2012 11:31 AM
iLok authorization problem PT9 - crossgrade from PT LE popheart Pro Tools 9 7 12-18-2010 03:07 PM
8 HD to 9 HD crossgrade authorization requirements rmprice Pro Tools 9 27 11-15-2010 12:43 PM
