  #6851
Old 08-30-2020, 03:57 PM
beggehorn beggehorn is offline
Default Re: i7 Builds - Specs and Results
Components should all be here tomorrow...
Specs:
ASUS WS x299 SAGE 10g
Intel i9-10980xe
Noctua NH-C14S
Patriot Viper Steel Series DDR4 64GB (4 x 16GB) 3200MHz
Samsung 860 EVO 1TB OS drive
Believe it or not, this build will be housed in an Antec rack mount case I purchased back in '99 for my first ProTools build and have been using ever since (!!)
Repurposing my existing hdd spinners for audio (500GB) and storage (4TB) as well as my Matrox C420 video card.
This will be a busy week! Wish me luck...
Windows 10 Pro x64
Avid HDX running PT Ultimate 2020.x
Intel i9-10980xe
64 GB DDR4 3200 RAM
Matrox C420
Avid Artist Mix
  #6852
Old 09-03-2020, 08:15 AM
Brandonx1 Brandonx1 is offline
Specs:
Intel i9-10980xe
Noctua NH-C14S
Wow super fast. We need to compare
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
  #6853
Old 09-03-2020, 09:28 PM
Hey Brandon!
For sure! Will be chipping away at all the installs and config for the rest of the week.
Issues so far:
- Long POST time (?). I'm not seeing any errors at all but there seems to be some self tests the MOBO goes through each time I startup/restart that takes at least 30 seconds before Windows starts to load. I've dug around the BIOS and disabled everything I thought might help but no change...Windows loading only takes about 12 seconds from Win logo to when the log-in screen appears... but even that surprises me.
- For some reason I had to move my Storage HDD from SATA port 1/2 to 3/4 (not sure which is which top to bottom) as the OS SSD that shared ports 1/2 was not running at 6Gps until I did.
- I have four unknown devices in device manager named "Performance Counters". I found only a couple recent references to that issue online. I had already installed the latest BIOS and chipset .inf before anything else. Not sure what this is or how it might affect things but certainly want to get it sorted.
- I'm also *slightly* concerned I might not have adequate cooling at the moment. The CPU is about 62C (package temp) with no load (@ stock 3.00 GHz CPU speed) at roughly 75-80F room temp (CPU fan speed in "Standard" mode). If I take the lid off the rack mount case, temp drops to about 56C. Aside from the Noctua CPU cooler, I have (2) Noctua 120mm case fans. However these fans are non-PWN (no speed control) and are designed for quiet operation. They run at about 1100 rpm and are super quiet but I'll probably need to replace those with PWM fans that I can set at a bit higher speed. Also considering changing adding a second fan to the top of the CPU cooler (its a design option of the cooler) though it would need to be a slim profile one (only have 1 1/2" of vertical clearance). I'll need to chat with Noctua and see if they recommend that configuration.
Probably won't even fire up Pro Tools until the weekend...
Windows 10 Pro x64
Intel i9-10980xe
64 GB DDR4 3200 RAM
Matrox C420
Avid Artist Mix
  #6854
Old 09-04-2020, 08:55 AM
The Weed's Avatar
The Weed The Weed is offline
I just upgraded my computers for the third and last time - I can't go any farther with the current configuration. I upped the RAM to 32 GB, added Samsung Evo 970 Plus NVMe M.2 drives in Vantec adapters with thermal tape and heatsinks and removed the Samsung Evo 850 SSDs and Western Digital Caviar Black internal drives and am using WD Passport 5 TB externals for backup. My temps for the CPU - Intel 4700K - and internal drives rarely go above 40 Celsius, normally 34 to 38 Celsius. Noctua CPU cooler with original almost 7 year old paste. Inside the case is almost dust free. I clean the screens monthly and have only had the interior "blasted" once and that was this year.
The original video card is fanless - Asus NVidia GT640. The case is a Silverstone Fortress which mounts the motherboard vertically. With an opening along the bottom of the case, the three 180 mm fans at the bottom draw air in and the 120 mm top fan draws it over the motherboard and its components. Not totally silent, but very cool.
Before you replace the fans, check out Corsair's Commander Pro fan controller. You may not have to replace those fans.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
  #6855
Old 09-04-2020, 10:02 AM
TOM@METRO's Avatar
^^^ Nice.^^^
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #6856
Old 09-04-2020, 10:39 AM
Thanks for the tip, Bruce. Looking into that..
Windows 10 Pro x64
Intel i9-10980xe
64 GB DDR4 3200 RAM
Matrox C420
Avid Artist Mix
  #6857
Old 09-23-2020, 09:14 AM
Just wanted to update the thread with where I ended up...
I went ahead and replaced my rack mount PC case's front fans with a pair of Noctua NF-A12x25 (PWM) fans. The extra air flow through the case brought down my CPU temps by 5+ degrees. With my CPU fans and case fans on maximum speed, my CPU never gets above 60 degrees now (even after a day of mixing a heavy session) and the fans are amazingly quiet.
I'm super happy with the new build. Still working with my template to refine the best way to avoid loading my middle cores but this is with me being super spoiled. I currently have multiple Acustica plugins, Elevate and a couple other beastly plug-ins all running on the 2 bus and I'm easily running at a HW buffer of 512. If I go to 1024, I exceed my maximum delay comp so hopefully with some load balancing (moving some of the 2 bus duties to by sub-mix busses) I'll find the sweet spot.
It is a breath of fresh air to mix without running into the inevitable need of committing/freezing while I'm trying to flow. Game changing upgrade for me!
Windows 10 Pro x64
Intel i9-10980xe
64 GB DDR4 3200 RAM
Matrox C420
Avid Artist Mix
  #6858
Old 09-27-2020, 06:03 AM
Hey Ben
Why are you running at 512? Can you run at lower hardware samples? I can't really run my threadripper at anything less than 256 but 512 is the best hardware buffer. I was hoping you would be able to run at a much lower buffer.
Curious if you are getting better perfoance with hyperthreading off. I don't think tools will use all the cores so might as well make each core as fast as possible..
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
  #6859
Old 09-28-2020, 08:50 PM
Believe it or not, I overload the middle core due to the plug-ins on my 2 bus if I go lower than 512 (primarily CPU hungry Acustica products). I'm still working on experimenting with moving some of the load to parallel sub-busses. While my middle core overloads, the rest are very low percentage. If I run more traditional plug-ins, I can definitely run at a lower buffer, however there's some magic with these plug-ins that is hard to beat.
Windows 10 Pro x64
Intel i9-10980xe
64 GB DDR4 3200 RAM
Matrox C420
Avid Artist Mix
  #6860
Old 09-29-2020, 08:49 AM
Originally Posted by Brandonx1 View Post
Hey Ben
Most of the HDX users I know will use higher buffer settings, but the way latency works is very different on HDX. As for hyperthreading, that's something that should be tried both ways as every system can be slightly different. Even with identical hardware, some odd piece of software can make things change. For Windows, users, its a quick trip thru BIOS or EUFI to change one setting.
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
