Re: PT8 constant -6101 cpu issue - HELP!
Yeah, I've tried that.
What's kind of strange is that it seems like the problem occures after a few hours of use. And even if I try to restart everthing it's no change. I just don't get it!
www.molotow.no |
I'm having the same issues with PT 8 and have posted about this in other similar threads.
are you recording to your internal drive??
www.myspace.com/maxpidge |
Have tried:
- a FW800-disk (on the same bus as the PFL) - a USB-disk - the internal one So far the USB-disk and the internal one seems to work the best. And yes, I know I'm not supposed to use the internal one, I just need to test everything :)
www.molotow.no |
How is that connected, exactly?
The way I would recommend doing it is to use a FW800-FW400 cable from the FW800 port on the computer to the FW400 port on the drive, assuming it has a FW400 port. Then connect the LightBridge to the other FW400 port. Ideally you would get a FW400 expresscard, like this one and connect the drive to that. Are you sure you've disabled firewire networking in the Network control panel? How did you disable Spotlight? Are there any other apps running in the background? |
#16
so far you've tested the 3 things YOUR NOT SUPPOSED TO DO, and you can't figure out why your system won't run........ yep must obviously be a problem on digi's end.........
#17
So you got any better idea of getting this to work?
The mac has two USB 2.0 ports, one FW400 and one FW800. What would you do? BTW I never have had ANY issue recording to a usb-drive or the internal drive ever, and I've used PT for 7 years. I guess that makes me an idiot.... Oh, and I found the issue. Go back to using LE and buying a 003 or 002. Talked to a bunch of pals using PT and EVERYONE has had the same problems with M-audio drivers. Not ONE of them has had a functional PTMP. All I hear is: M-audio drivers are terrible! What happens is that the error accures after a few hours of use. Before that everything is fine (no matter what connections I use of what drive I record to/playback from). Then: ERROR. I have even tried 3 different M-audio interfaces and two different macs. Same issue. I'm selling off my M-audio interfaces and getting back my LE-rig. It's not just worth it using all this energy on it.
www.molotow.no |
#18
You can find Express Cards here http://eshop.macsales.com/shop/noteb...ress34_Cardbus for as little as $40, depending on what you want.
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
#19
Yes, I know about the FW-bus issue, and that's why I have tried with the internal and and usb-disk.
Anyways, this applies to two different PFLB and two different macs, and adding that to the (horror)stories I've hear lately (from peeps I trust) it's got to be a driver issue. Try searching on the 6101 issue on this forum. I'm not the only one....
www.molotow.no |
#20
I'm just telling you as long as I've been doing this with M-Audio, not to mention the 5+ years of PTHD, I've never had a problem as long as there were separate FW busses. Even Digital Performer prefers working this way, regardless of interface or drivers.
I'm sure there's lots of horror stories about M-Audio drivers, but I've never had issues using multiple traffic options.
ERROR -6101 constant | bakerja | Pro Tools 11 | 11 | 11-08-2013 07:27 AM |
Constant -6101 errors while recording | bleen | macOS | 21 | 05-29-2013 05:17 PM |
PT8 constant -6101 cpu issue, Let's do something | mistlabz | Pro Tools M-Powered (Mac) | 47 | 08-31-2009 05:15 AM |
Constant error messages (-6101), (-9128) | MdotCash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 42 | 07-14-2009 03:15 PM |
Constant -6101 errors | mpeddle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 03-10-2009 09:03 AM |
