Old 04-13-2006, 06:58 PM
majorlabel majorlabel is offline
Default playback limited to 16 tracks ??!!
I am using 3 delta 1010lt's through a 24 track analog mixer...24 track recording and playback works fine on sonar and other progs but playback is limited to 16 tracks on PT7.
Any suggestions ??
Old 04-13-2006, 07:18 PM
Skyflash Skyflash is offline
Default Re: playback limited to 16 tracks ??!!
Using multiple interfaces is not supported. They may show up in the hardware
setup and all may seem fine and dandy untill you try to use them then you
start having problems.
2006 'Blackbook' Core Duo 2.0 ghz.
2 gig OWC RAM
10.5.8
PT Mpowered 8.04, Logic 9.1.1
Waves SSL,Omnisphere,Korg Legacy Digital
Absynth 4, EZ Drummer
Project Mix I/O w/ Black Lion Mod
Axiom 61,25, Korg Nano Pad
Old 04-13-2006, 07:20 PM
JoePaz JoePaz is offline
I'm guessing those are 16 stereo tracks. PT7-MP is limited to playing back 32 voices max at a time. Each stereo track is 2 voices, so 2 X 16 = 32 voices. The only way to increase that is to purchase the Music Production Toolkit. That will get you up to 48 tracks at once. That's 48 tracks (either stereo or mono), not voices. It lists for $495, but you get some nice plugins with it too, not just the track increase. I picked up a copy from audiomidi.com for $449. More info here - http://www.digidesign.com/products/d...roduct_id=4865 .
Old 04-13-2006, 07:58 PM
dogselur dogselur is offline
I got quoted a better price(not that you want to hear that after you've already made the purchase ) from alto music. check it out. email jon@altomusic.com
Old 04-13-2006, 11:28 PM
no that's 16 mono tracks...three 8 in 8 out analog cards..all 24 show up in the I/O setup and recording to any of the 24 is not a problem..only playback...weird thing is outputs to tracks 17-24 are allowed in the output setup but it just does not actually output the audio to the interface
Old 04-13-2006, 11:31 PM
I'm not sure this would qualify as "multiple interfaces" they are connected by spdif and work as one unit...they show up fine in the I/O setup and Delta Audio panel...they work fine under all other DAE programs.
PT11 Limited Playback Engine Option Hadassah Pro Tools 11 1 12-18-2013 10:40 AM
I seem to be very limited in the amount of tracks I can playback matt0722 Pro Tools 10 7 07-23-2012 01:26 PM
PT9 Limited Playback of WMV bwacs Windows 0 05-19-2011 10:26 AM
limited tracks klangart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-25-2003 12:55 AM
Limited record tracks in ext sync Mikenutmeg Pro Tools TDM Systems (Mac) 3 06-25-2001 09:21 AM
